See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3465/changes>
Changes:
[mcr] Updated German language files
[...truncated 25526 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/test/java>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/src/main/resources>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-3,5,main] waiting
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] waiting
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] waiting
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.512 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.207 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Results :
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target/wps-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target/wps-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core>
[INFO] Copying 10 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/resources>
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot com.googlecode.jaitools:zonalstats:1.0-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot com.googlecode.jaitools:zonalstats:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot com.googlecode.jaitools:zonalstats:1.0-SNAPSHOT: checking for updates from osgeo
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/zonalstats/1.0-SNAPSHOT/zonalstats-1.0-SNAPSHOT.pom
[INFO] snapshot com.googlecode.jaitools:operator:1.0-SNAPSHOT: checking for updates from jaitools-snapshots
[WARNING] *** CHECKSUM FAILED - Error retrieving checksum file for com/googlecode/jaitools/operator/1.0-SNAPSHOT/maven-metadata.xml - IGNORING
[INFO] snapshot com.googlecode.jaitools:operator:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot com.googlecode.jaitools:operator:1.0-SNAPSHOT: checking for updates from osgeo
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/operator/1.0-SNAPSHOT/operator-1.0-SNAPSHOT.pom
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
GroupId: com.googlecode.jaitools
ArtifactId: operator
Version: 1.0-SNAPSHOT
Reason: Unable to locate resource in repository
com.googlecode.jaitools:operator:pom:1.0-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
jaitools-snapshots (http://oss.sonatype.org/content/repositories/snapshots/),
opengeo (http://repo.opengeo.org/),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org)
[INFO] Total time: 10 minutes 28 seconds
[INFO] Finished at: Mon Jan 17 14:45:52 UTC 2011
[INFO] Final Memory: 78M/274M
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
