See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3471/changes>
Changes:
[jdeolive] fixing community release profile, removing wps (moved to extension) and disabling python
[...truncated 9666 lines...]
at java.lang.reflect.Method.invoke(Method.java:592)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
18 Jan 18:00:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1890256700521031557data>
18 Jan 18:00:58 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1161)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:204)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:74)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1144)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:482)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:226)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1155)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1174)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1115)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:541)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:41)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:37)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:141)
at sun.reflect.GeneratedMethodAccessor152.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.235 sec
Running org.geoserver.wms.map.GIFMapResponseTest
18 Jan 18:00:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7597057100306405367data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.569 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7842593486099650581data>
18 Jan 18:00:58 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.477 sec
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
18 Jan 18:01:00 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
18 Jan 18:01:00 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Running org.geoserver.wms.RenderingBufferTest
18 Jan 18:01:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock467651292762153911data>
18 Jan 18:01:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8757531499044466339data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8361810394049782539data>
18 Jan 18:01:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7948454993112267561data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4284825034141562389data>
18 Jan 18:01:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4403189683485411319data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.741 sec
Running org.geoserver.kml.GeoSearchKMLTest
18 Jan 18:01:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock9025383981265506396data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8048071659261890849data>
18 Jan 18:01:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6071574441249483132data>
18 Jan 18:01:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5237264292977073073data>
18 Jan 18:01:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2035325030357928557data>
18 Jan 18:01:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7455151293947280913data>
18 Jan 18:01:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3568324521742906243data>
18 Jan 18:01:10 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock597871249284258731data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.438 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3052252732007881831data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.828 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
18 Jan 18:01:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5343897628030449881data>
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.34 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
18 Jan 18:01:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6287769216756954849data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.495 sec
Running org.geoserver.kml.KMZMapProducerTest
18 Jan 18:01:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8678672804926998088data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.053 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
18 Jan 18:01:14 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
18 Jan 18:01:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5801928523543171191data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.724 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
18 Jan 18:01:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6467621816666021155data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.764 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Tests run: 239, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/2.7-SNAPSHOT/gt-xml-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-gtopo30/2.7-SNAPSHOT/gt-gtopo30-2.7-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: Connection refused
org.geotools:gt-xml:jar:2.7-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
opengeo (http://repo.opengeo.org/),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org)
Path to dependency:
1) org.geoserver:wms:jar:2.2-SNAPSHOT
2) org.geotools:gt-wfs:jar:2.7-SNAPSHOT
3) org.geotools:gt-xml:jar:2.7-SNAPSHOT
[INFO] Total time: 6 minutes 34 seconds
[INFO] Finished at: Tue Jan 18 18:01:17 UTC 2011
[INFO] Final Memory: 60M/239M
