[Geoserver-devel] Build failed in Hudson: geoserver-trunk #349
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/349/changes
started
Updating https://svn.codehaus.org/geoserver/trunk/geoserver
U web/src/main/java/ApplicationResources_fr.properties
U web/src/main/java/ApplicationResources.properties
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/minimal
At revision 8464
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img
At revision 6386
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib
At revision 6386
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
At revision 8464
At revision 8464
FATAL: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
  at javax.xml.transform.TransformerFactory.newInstance(TransformerFactory.java:108)
  at hudson.scm.SubversionChangeLogBuilder.createTransformerHandler(SubversionChangeLogBuilder.java:158)
  at hudson.scm.SubversionChangeLogBuilder.run(SubversionChangeLogBuilder.java:66)
  at hudson.scm.SubversionSCM.calcChangeLog(SubversionSCM.java:228)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:320)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
  at hudson.model.Run.run(Run.java:659)
  at hudson.model.Build.run(Build.java:101)
  at hudson.model.ResourceController.execute(ResourceController.java:70)
  at hudson.model.Executor.run(Executor.java:65)
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/350/changes
started
U wms/src/main/java/org/vfny/geoserver/wms/responses/helpers/WMSCapsTransformer.java
At revision 8468
At revision 6386
At revision 6386
At revision 8468
At revision 8466
WARNING: clock of the subversion server appears to be out of sync. This can result in inconsistent check out behavior.
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/351/changes
started
U web/src/main/java/org/vfny/geoserver/action/data/TypesEditorAction.java
U web/src/main/java/org/vfny/geoserver/action/data/StylesSelectAction.java
U web/src/main/java/org/vfny/geoserver/action/data/CoveragesEditorAction.java
At revision 8470
At revision 6386
At revision 6386
At revision 8470
At revision 8470
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/352/changes
