[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3553
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3553/changes&gt;
Changes:
[dany111] GEOS-4370
[...truncated 2082 lines...]
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Feb 11, 2011 1:49:50 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 56, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.088 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.004 sec <<< FAILURE!
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Results :
Tests in error:
  org.geoserver.catalog.impl.CatalogBuilderTest
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest)
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
  testBasic(org.geoserver.ows.URLManglersTest)
  testKVP(org.geoserver.ows.URLManglersTest)
  testProxyBase(org.geoserver.ows.URLManglersTest)
  testValid(org.vfny.geoserver.util.SLDValidatorTest)
  testInvalid(org.vfny.geoserver.util.SLDValidatorTest)
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
Tests run: 263, Failures: 0, Errors: 14, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 29 seconds
[INFO] Finished at: Fri Feb 11 13:49:50 UTC 2011
[INFO] Final Memory: 51M/216M
Failed to send e-mail to dany111 because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3554/&gt;
