[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3579
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3579/changes&gt;
Changes:
[aaime] [GEOS-4376] Pass down background color to readers in direct rendering path
[...truncated 8647 lines...]
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy14.describeFeatureType(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1154)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1173)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:542)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:523)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:795)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:759)
  at org.geoserver.wfs.v1_1.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:179)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
  at sun.reflect.GeneratedMethodAccessor172.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
17 Feb 10:39:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock504126883577277848data&gt;
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.764 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock1031195600054385764data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8784003524142772327data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8509847221645814995data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock9187004196392265822data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6230378028584517747data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.237 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3006077803726049235data&gt;
Feature type cite:InvalidTypeName unknown
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock7093101512492621200data&gt;
17 Feb 10:39:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock5760412124191447141data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2634972861517584830data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3688761639601059068data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.492 sec
Running org.geoserver.wfs.response.ShapeZipTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock932144973524175330data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6790637893570575794data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock4799249417179203676data&gt;
17 Feb 10:39:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock1340329527268931898data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8833881653258257897data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3182919048834432751data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock5890434790699679508data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6573205909929382469data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2492814743323711888data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock174673805252237765data&gt;
17 Feb 10:39:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8235724406219104650data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8561164948623910943data&gt;
17 Feb 10:39:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock459205698072031961data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3290641382286359960data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock9027046102808608306data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.155 sec
Running org.geoserver.wfs.GetCapabilitiesTest
17 Feb 10:39:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8164995402924840539data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.366 sec
Results :
Tests run: 243, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms&gt;
[INFO] Copying 1 resource
[INFO] Copying 9 resources
[INFO] snapshot org.geotools:gt-svg:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:2.8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-main/2.8-SNAPSHOT/gt-main-2.8-SNAPSHOT.jar
[INFO] Compiling 164 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java&gt;:\[63,50\] package org.geotools.coverage.renderedimage.viewer does not exist
[INFO] Total time: 2 minutes 44 seconds
[INFO] Finished at: Thu Feb 17 10:39:24 UTC 2011
[INFO] Final Memory: 62M/312M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3580/changes&gt;
