[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3584
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3584/changes&gt;
Changes:
[aaime] [GEOS-4385] Using a global thread pool for rendering might break stores that make heavy usage of thread locals
[...truncated 10487 lines...]
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1154)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1173)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:542)
  at org.geoserver.wms.RenderingBufferTest.testGetMapExplicitBuffer(RenderingBufferTest.java:71)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
  at sun.reflect.GeneratedMethodAccessor157.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
18 Feb 10:49:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7355864746710973883data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4755177201802127859data&gt;
18 Feb 10:49:44 ERROR [geoserver.ows] -
java.util.concurrent.RejectedExecutionException
  at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:1478)
  at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:384)
  at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:857)
  at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:31)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:741)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:445)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:206)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:121)
  at org.geoserver.wms.GetMap.run(GetMap.java:461)
  at org.geoserver.wms.GetMap.run(GetMap.java:110)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:352)
  at sun.reflect.GeneratedMethodAccessor267.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy15.getMap(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor266.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.geoserver.wms.RenderingBufferTest.testGetMapConfiguredBuffer(RenderingBufferTest.java:99)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4688645959632175037data&gt;
Tests run: 6, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 1.078 sec <<< FAILURE!
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1762541867958821015data&gt;
18 Feb 10:49:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6109659093213543178data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2415986301138917373data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4462640379041685353data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8893299755050059597data&gt;
18 Feb 10:49:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5541633012674207553data&gt;
18 Feb 10:49:46 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1205544954871603586data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2636531736532634579data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.194 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
18 Feb 10:49:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock129000241176223291data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.8 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4943970940234618832data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.8 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
18 Feb 10:49:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7717769682273541669data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.175 sec
Running org.geoserver.kml.KMZMapProducerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3196057808097216046data&gt;
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.21 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
18 Feb 10:49:49 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
18 Feb 10:49:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4726497311783745524data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.135 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
18 Feb 10:49:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3023635305646295430data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Failed tests:
  testSLDWithInlineFeatureWMS(org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest)
  testSLDBody(org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest)
  testWorkspaceQualified(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testImage(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testSldBody(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testSldBody11(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testSldBodyPost(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testSldBodyPost11(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testXmlPost(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testLayerQualified(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest)
  testSldBody11(org.geoserver.wms.wms_1_3.GetMapIntegrationTest)
  testSldBody10(org.geoserver.wms.wms_1_3.GetMapIntegrationTest)
  testSldBody10Validate(org.geoserver.wms.wms_1_3.GetMapIntegrationTest)
  testSldBody11Validate(org.geoserver.wms.wms_1_3.GetMapIntegrationTest)
  testSldBody11NoVersion(org.geoserver.wms.wms_1_3.GetMapIntegrationTest)
  testGetMapNoBuffer(org.geoserver.wms.RenderingBufferTest)
  testGetMapExplicitBuffer(org.geoserver.wms.RenderingBufferTest)
  testGetMapConfiguredBuffer(org.geoserver.wms.RenderingBufferTest)
Tests in error:
  testRasterPlacemarkTrue(org.geoserver.kml.KMLTransformerTest)
  testRasterPlacemarkFalse(org.geoserver.kml.KMLTransformerTest)
  testDefaultStyle(org.geoserver.wms.map.GIFMapResponseTest)
  testSimpleGetMapQuery(org.geoserver.wms.map.GIFMapResponseTest)
  testBlueLake(org.geoserver.wms.map.GIFMapResponseTest)
  testRenderingErrorsHandling(org.geoserver.wms.map.GIFMapResponseTest)
  testDefaultStyle(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  testSimpleGetMapQuery(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  testBlueLake(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  testRenderingErrorsHandling(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  test(org.geoserver.kml.KMZMapProducerTest)
Tests run: 240, Failures: 18, Errors: 11, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 37 seconds
[INFO] Finished at: Fri Feb 18 10:49:50 UTC 2011
[INFO] Final Memory: 63M/305M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3585/&gt;
[...truncated 10486 lines...]
18 Feb 11:28:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4765973566628017584data&gt;
18 Feb 11:28:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2913825189285656602data&gt;
18 Feb 11:28:45 ERROR [geoserver.ows] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5169388389550159440data&gt;
Tests run: 6, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 1.077 sec <<< FAILURE!
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1835661585041911406data&gt;
18 Feb 11:28:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5835552117107573245data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4384106979638297414data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5529239772039064694data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6431728683899555516data&gt;
18 Feb 11:28:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5265053874723474008data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4716998605152137888data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2873646960339320230data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.564 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6932445644689134811data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
18 Feb 11:28:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7382852272473580835data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.843 sec
18 Feb 11:28:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2220918423542987146data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7241892512317699415data&gt;
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.219 sec <<< FAILURE!
18 Feb 11:28:49 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock232676157820238472data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.486 sec
18 Feb 11:28:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8975439107333075027data&gt;
18 Feb 11:28:51 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Results :
Failed tests:
Tests in error:
[INFO] Total time: 3 minutes 25 seconds
[INFO] Finished at: Fri Feb 18 11:28:51 UTC 2011
[INFO] Final Memory: 63M/313M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3586/changes&gt;
