[Geoserver-devel] Build failed in Hudson: geoserver-trunk #362
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/362/changes
[...truncated 3101 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
  at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
  ... 41 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
  at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:147)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
  ... 43 more
01 Mar 03:21:33 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Version has not been specified
  at org.geoserver.wcs.kvp.DescribeCoverageKvpRequestReader.read(DescribeCoverageKvpRequestReader.java:54)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1038)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:371)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:185)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:710)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:305)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:286)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:453)
  at org.geoserver.wcs.DescribeCoverageTest.testDescribeMissingVersion(DescribeCoverageTest.java:47)
01 Mar 03:21:35 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:37)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:411)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:520)
  at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:67)
  ... 40 more
  ... 42 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.612 sec
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.524 sec
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.wcs.GetCoverageTest
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at java.security.AccessController.doPrivileged(Native Method)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
  at sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
  at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:610)
  at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:209)
  at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:327)
  at org.geoserver.wcs.GetCoverageTest.executeGetCoverageKvp(GetCoverageTest.java:368)
  at org.geoserver.wcs.GetCoverageTest.testKvpBasic(GetCoverageTest.java:63)
Tests run: 16, Failures: 0, Errors: 13, Skipped: 0, Time elapsed: 1.44 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.364 sec
Running org.geoserver.wcs.GetCoverageMultipartEncodingTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
Running org.geoserver.wcs.GetCoverageSupportsStoreTrueTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.008 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@1654
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.604 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 17, Failures: 0, Errors: 17, Skipped: 0, Time elapsed: 0 sec <<< FAILURE!
Results :
Tests in error:
  testWrongFormatParams(org.geoserver.wcs.GetCoverageTest)
  testDefaultGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testGridOffsetsSubsample(org.geoserver.wcs.GetCoverageTest)
  testInvalidRangeSubset(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyInterpolation(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyField(org.geoserver.wcs.GetCoverageTest)
  testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testArcgridException(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testTiffOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testPngOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageSupportsStoreTrueTest)
  testGetBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testNoServiceContactInfo(org.geoserver.wcs.GetCapabilitiesTest)
  testPostBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceInferiorGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceInferiorPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceEqualsGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceEqualsPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceSuperiorGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceSuperiorPost(org.geoserver.wcs.GetCapabilitiesTest)
  testSectionsBogus(org.geoserver.wcs.GetCapabilitiesTest)
  testSectionsAll(org.geoserver.wcs.GetCapabilitiesTest)
  testOneSection(org.geoserver.wcs.GetCapabilitiesTest)
  testTwoSection(org.geoserver.wcs.GetCapabilitiesTest)
Tests run: 76, Failures: 0, Errors: 36, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 42 seconds
[INFO] Finished at: Sat Mar 01 03:21:40 EST 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/364/changes
Changes:
[dgricci] Update of French resources
[...truncated 368 lines...]
758/1124K
762/1124K
766/1124K
770/1124K
772/1124K
776/1124K
776/1124K
777/1124K
779/1124K
780/1124K
783/1124K
787/1124K
787/1124K
790/1124K
793/1124K
797/1124K
799/1124K
803/1124K
807/1124K
810/1124K
813/1124K
816/1124K
820/1124K
824/1124K
828/1124K
832/1124K
832/1124K
834/1124K
835/1124K
838/1124K
842/1124K
844/1124K
847/1124K
851/1124K
855/1124K
859/1124K
863/1124K
864/1124K
866/1124K
870/1124K
872/1124K
873/1124K
876/1124K
878/1124K
879/1124K
883/1124K
885/1124K
889/1124K
893/1124K
897/1124K
900/1124K
904/1124K
908/1124K
912/1124K
916/1124K
919/1124K
923/1124K
923/1124K
924/1124K
927/1124K
930/1124K
934/1124K
934/1124K
936/1124K
939/1124K
941/1124K
945/1124K
949/1124K
953/1124K
957/1124K
960/1124K
964/1124K
968/1124K
968/1124K
971/1124K
975/1124K
979/1124K
983/1124K
987/1124K
991/1124K
994/1124K
998/1124K
998/1124K
1001/1124K
1005/1124K
1009/1124K
1013/1124K
1013/1124K
1016/1124K
1018/1124K
1021/1124K
1025/1124K
1025/1124K
1026/1124K
1030/1124K
1034/1124K
1038/1124K
1039/1124K
1040/1124K
1043/1124K
1046/1124K
1047/1124K
1050/1124K
1052/1124K
1054/1124K
1057/1124K
1059/1124K
1062/1124K
1066/1124K
1069/1124K
1070/1124K
1071/1124K
1074/1124K
1076/1124K
1080/1124K
1081/1124K
1084/1124K
1088/1124K
1092/1124K
1096/1124K
1100/1124K
1104/1124K
1107/1124K
1110/1124K
1111/1124K
1112/1124K
1114/1124K
1115/1124K
1118/1124K
1121/1124K
1122/1124K
1125/1124K
1128/1124K
1132/1124K
1132/1124K
1124K downloaded
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer Maven Plugins
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[WARNING] repository metadata for: 'artifact org.apache.maven.plugins:maven-plugin-plugin' could not be retrieved from repository: refractions-plugins due to an error: Error transferring file
[INFO] Repository 'refractions-plugins' will be blacklisted
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
  org.geotools:gt2-api:jar:2.5-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver.maven:config:maven-plugin:1.7.0-SNAPSHOT
  2) org.geotools:gt2-api:jar:2.5-SNAPSHOT
Caused by I/O exception: Connection refused
[INFO] Total time: 415 minutes 18 seconds
[INFO] Finished at: Sat Mar 01 16:32:11 EST 2008
[INFO] Final Memory: 20M/36M
Failed to send e-mail to dgricci because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/365/changes
