See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3632/changes>
Changes:
[NielsCharlier] Property Selection with namespace/nested paths GEOS-4380
[...truncated 23526 lines...]
</ex:nestedFeature>
<ex:nestedFeature xlink:href="http://example.com/UrnResolver/?uri=1"/>
</ex:geomContainer>
</gml:featureMember>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:pos>31.29 42.58</gml:pos>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:exterior>
<gml:LinearRing>
<gml:posList>52.5 -1.2 52.6 -1.2 52.6 -1.1 52.5 -1.1 52.5 -1.2</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature>
<ex:nestedGeom gml:id="secondNested.1">
<ex:name>NAME</ex:name>
<ex:nestedFeature>
<ex:nestedGeom gml:id="thirdNested.2">
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature xlink:href="http://example.com/UrnResolver/?uri=2"/>
</ex:geomContainer>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.687 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
04 Mar 05:04:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1916150301587239238data>
Mar 4, 2011 5:04:51 AM org.geoserver.test.SameNameDiffNamespaceTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2011-03-04T05:04:51.463Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1916150301587239238data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:MyTestFeature gml:id="f1">
<gml:name>Feature 1</gml:name>
<ex:name>First Feature</ex:name>
</ex:MyTestFeature>
<gml:featureMember>
<ex:MyTestFeature gml:id="f2">
<gml:name>Feature 2</gml:name>
<ex:name>Second Feature</ex:name>
</ex:MyTestFeature>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.18 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock7156898359372103420data>
Mar 4, 2011 5:04:52 AM org.geoserver.test.PolymorphismInlineWfsTest testGetFeature
INFO: WFS GetFeature&typename=ex:PolymorphicFeature response:
<wfs:FeatureCollection numberOfFeatures="6" timeStamp="2011-03-04T05:04:52.652Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock7156898359372103420data/featureTypes/ex_PolymorphicFeature/polymorphism.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f1">
<ex:firstValue>
<gsml:CGI_TermValue gsml:qualifier="approximate">
<gsml:value codeSpace="codespace">1</gsml:value>
</gsml:CGI_TermValue>
</ex:firstValue>
</ex:PolymorphicFeature>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f2">
<ex:firstValue>
<gsml:CGI_TermValue>
<gsml:value codeSpace="some:uri">x</gsml:value>
</ex:firstValue>
<ex:firstValue>
<gsml:value codeSpace="codespace">0</gsml:value>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f3">
<ex:firstValue>
<gsml:value codeSpace="some:uri">y</gsml:value>
</ex:firstValue>
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f4">
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f5">
<ex:firstValue>
</ex:firstValue>
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f6">
<ex:firstValue>
<gsml:value codeSpace="codespace">1000</gsml:value>
</ex:firstValue>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.test.MappingNameTest
04 Mar 05:04:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1647176027296525843data>
Mar 4, 2011 5:04:54 AM org.geoserver.test.MappingNameTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2011-03-04T05:04:54.923Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf1">
<gsml:observationMethod>
<gsml:value codeSpace="codespace01">value01</gsml:value>
</gsml:observationMethod>
<gsml:value codeSpace="codespace02">value02</gsml:value>
<gsml:shape>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>-23.6701 133.8855</gml:pos>
</gml:Point>
</gsml:shape>
</gsml:MappedFeature>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf2">
<gsml:value codeSpace="codespace03">value03</gsml:value>
<gsml:shape>
<gml:pos>-29.0434 167.9388</gml:pos>
</gml:Point>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf3">
<gsml:shape>
<gml:pos>-12.1883 96.8339</gml:pos>
</gml:Point>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
<gsml:shape>
<gml:pos>-34.9502 117.8102</gml:pos>
</gml:Point>
</gsml:shape>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.232 sec
Running org.geoserver.test.PropertyEncodingOrderTest
04 Mar 05:04:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock2818524949744325046data>
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 44.413 sec <<< FAILURE!
Results :
Tests in error:
Tests run: 66, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 9 minutes 2 seconds
[INFO] Finished at: Fri Mar 04 05:05:39 UTC 2011
[INFO] Final Memory: 74M/313M
Failed to send e-mail to NielsCharlier because no e-mail address is known, and no default e-mail domain is configured
