[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3679
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3679/&gt;
[...truncated 20249 lines...]
21 Mar 14:55:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8507148633810111011data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5304614645938050714data&gt;
21 Mar 14:55:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5758611659743857204data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock432675299190143600data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5428311486948385627data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.112 sec
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7660368513238755688data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5635247007448347013data&gt;
21 Mar 14:55:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3370323232179362359data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3223917756958578315data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock121942873917659797data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4696307189458033313data&gt;
21 Mar 14:55:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2670053410476293426data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4483664580516176185data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.128 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock172899058134918625data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.258 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
21 Mar 14:55:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2450297933646541415data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.484 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
21 Mar 14:55:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2268614918468421079data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Running org.geoserver.kml.KMZMapProducerTest
21 Mar 14:56:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2026656638107391516data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.269 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
21 Mar 14:56:00 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8480958697586845333data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.17 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
21 Mar 14:56:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4787462344862225727data&gt;
21 Mar 14:56:01 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Tests run: 245, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/2.8-SNAPSHOT/org.w3.xlink-2.8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/2.8-SNAPSHOT/gt-coverage-2.8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/2.8-SNAPSHOT/gt-data-2.8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.2-SNAPSHOT/wms-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc&gt;
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-core:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-core:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geowebcache/geowebcache/1.2.5-SNAPSHOT/geowebcache-1.2.5-SNAPSHOT.pom
4/15K
8/15K
12/15K
15/15K
15K downloaded (geowebcache-1.2.5-SNAPSHOT.pom)
[INFO] snapshot org.geowebcache:gwc-georss:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-georss:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-kml:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-rest:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-tms:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-ve:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wms:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.2.5-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.gwc.CatalogConfigurationTest
21 Mar 14:56:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/./target/mock1460243322625979132data&gt;
Mar 21, 2011 2:56:11 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
21 Mar 14:56:11 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
21 Mar 14:56:11 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt; contained no layers.
21 Mar 14:56:11 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml&gt;
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 6.346 sec <<< FAILURE!
Running org.geoserver.gwc.wms.CachingExtendedCapabilitiesProviderTest
21 Mar 14:56:14 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
21 Mar 14:56:14 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt; contained no layers.
21 Mar 14:56:14 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml&gt;
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 4.557 sec <<< FAILURE!
Running org.geoserver.gwc.GWCIntegrationTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.295 sec <<< FAILURE!
Results :
Failed tests:
  testPngIntegration(org.geoserver.gwc.GWCIntegrationTest)
Tests in error:
  testInit(org.geoserver.gwc.CatalogConfigurationTest)
Tests run: 3, Failures: 1, Errors: 2, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 39 seconds
[INFO] Finished at: Mon Mar 21 14:56:18 UTC 2011
[INFO] Final Memory: 62M/269M
Don't panic, checking what's going on (so many local branches...)
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3680/changes&gt;
