[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3684
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3684/changes&gt;
Changes:
[aaime] [GEOS-4438] KML may return no data if the style has rules with scale dependencies
[...truncated 20069 lines...]
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
  at sun.reflect.GeneratedMethodAccessor158.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
21 Mar 20:39:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock2036133845218652295data&gt;
21 Mar 20:39:54 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
  at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1152)
  at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:203)
  at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:73)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1144)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:482)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:226)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1154)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1173)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:542)
  at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:67)
  at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:63)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.957 sec
Running org.geoserver.wms.map.GIFMapResponseTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4821149962665646797data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.589 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
21 Mar 20:39:55 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
21 Mar 20:39:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3109999628407207516data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.819 sec
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
21 Mar 20:39:55 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
21 Mar 20:39:56 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Running org.geoserver.wms.RenderingBufferTest
21 Mar 20:39:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock25905581440419707data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock188032912051855274data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4745085533681743447data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock3214477593505281319data&gt;
21 Mar 20:39:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5553144276332877633data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7494914295016001551data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.269 sec
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7054015851758247059data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5911740519060410645data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6009556537612780137data&gt;
21 Mar 20:39:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1807058975354903896data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock31761234515356652data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4192755581928115056data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8037646850564998742data&gt;
21 Mar 20:39:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4478503790008300574data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.071 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1037333827371418837data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.258 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5878955200757232327data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.055 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
21 Mar 20:40:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock963376844635306664data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.194 sec
Running org.geoserver.kml.KMZMapProducerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock4340097884509623348data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.271 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
21 Mar 20:40:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock199963411192446879data&gt;
21 Mar 20:40:01 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.384 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
21 Mar 20:40:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6062733657701746333data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Tests in error:
  org.geoserver.kml.KMLTest
Tests run: 242, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 30 seconds
[INFO] Finished at: Mon Mar 21 20:40:03 UTC 2011
[INFO] Final Memory: 63M/304M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3685/changes&gt;
