[Geoserver-devel] Build failed in Hudson: geoserver-trunk #375
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/375/changes
started
Checking out a fresh workspace because the workspace is not https://svn.codehaus.org/geoserver/trunk/geoserver
FATAL: Unable to delete http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform
java.io.IOException: Unable to delete http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform
  at hudson.Util.deleteFile(Util.java:171)
  at hudson.Util.deleteRecursive(Util.java:178)
  at hudson.Util.deleteContentsRecursive(Util.java:142)
  at hudson.Util.deleteRecursive(Util.java:177)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:393)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:353)
  at hudson.FilePath.act(FilePath.java:301)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:347)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:300)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
  at hudson.model.Run.run(Run.java:659)
  at hudson.model.Build.run(Build.java:101)
  at hudson.model.ResourceController.execute(ResourceController.java:70)
  at hudson.model.Executor.run(Executor.java:65)
