See http://geo.openplans.org:8080/hudson/job/geoserver-trunk/38/changes
Changes:
[jdeolive] implemented GetGmlObject and GetFeature xlink
[jdeolive] support for handling xlink properties on a query
[jdeolive] removed throws SAXException from encoder
[jdeolive] added geotools factory iterator provider to the mix
[...truncated 269 lines...]
[INFO] Building Open Web Service Model
[INFO] ----------------------------------------------------------------------------
[INFO] [clean:clean]
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 62 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] snapshot org.geotools:gt2-xml-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 66 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.beans.factory.xml.XmlBeanDefinitionReader).
log4j:WARN Please initialize the log4j system properly.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.644 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.198 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Main Module
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 116 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] Compiling 5 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.205 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Jan 3, 2008 2:32:17 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/test40043template
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.131 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 34 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Validation Module
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target
[INFO] Compiling 6 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Model
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target
[INFO] Compiling 80 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Module
[INFO] artifact org.geotools.maven:gt2-xmlcodegen: checking for updates from central
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.5-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.5-SNAPSHOT: checking for updates from refractions-plugins
[INFO] Deleting directory http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 160 source files to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/GetGmlObject.java :[9,25] cannot find symbol
symbol : class GmlObjectStore
http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/GetGmlObject.java :[66,31] cannot find symbol
http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/GetGmlObject.java :[68,38] cannot find symbol
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Thu Jan 03 14:32:42 GMT-05:00 2008
[INFO] Final Memory: 51M/246M
