See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3856/changes>
Changes:
[bencaradocdavies] GEOS-4496: Support app-schema in WFS GML 3.2 output
[...truncated 15524 lines...]
at java.lang.reflect.Method.invoke(Method.java:592)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
... 51 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:128)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 53 more
29 Apr 04:41:51 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:751)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1192)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1211)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1152)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:765)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:692)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:899)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:882)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:204)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
... 52 more
... 54 more
java.io.IOException
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:580)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:561)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:833)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:797)
at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:211)
... 51 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:173)
... 53 more
SchemaLocation: schemaLocation value = 'http://localhost:8080/geoserver/schemas/wcs/1.1.1/wcsGetCapabilities.xsd’ must have even number of URI's.
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.203 sec
Results :
Tests run: 79, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-postgis/8-SNAPSHOT/gt-jdbc-postgis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/8-SNAPSHOT/gt-validation-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs>
[INFO] Copying 10 resources
[INFO] Copying 1 resource
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/8-SNAPSHOT/gt-xsd-fes-8-SNAPSHOT.jar
[INFO] Compiling 178 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/GML32OutputFormat.java>:\[68,18\] cannot find symbol
symbol : variable CANONICAL_SCHEMA_LOCATION
[INFO] Total time: 2 minutes 10 seconds
[INFO] Finished at: Fri Apr 29 04:41:56 UTC 2011
[INFO] Final Memory: 60M/268M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
