[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3910
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3910/&gt;
[...truncated 615 lines...]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.ows:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 80 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes&gt;
[INFO] Copying 4 resources
[INFO] Compiling 17 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ows.DispatcherTest
May 9, 2011 12:20:41 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
May 9, 2011 12:20:42 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Mon May 09 00:20:42 UTC 2011]; root of context hierarchy
May 9, 2011 12:20:42 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
May 9, 2011 12:20:42 AM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
May 9, 2011 12:20:42 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
May 9, 2011 12:20:43 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Mon May 09 00:20:43 UTC 2011]; root of context hierarchy
May 9, 2011 12:20:43 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
May 9, 2011 12:20:43 AM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
May 9, 2011 12:20:43 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.128 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.465 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main&gt;
[INFO] Copying 28 resources
[INFO] Copying 1 resource
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 294 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/util/LegacyCatalogImporter.java&gt;:\[609,15\] cannot find symbol
symbol : constructor NumberRange(java.lang.Double,java.lang.Double)
[INFO] Total time: 43 seconds
[INFO] Finished at: Mon May 09 00:20:59 UTC 2011
[INFO] Final Memory: 49M/216M
GeoTools NumberRange deprecated methods were removed. Trivial fix now in testing.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Unless Jody beats me to it ... which he did. :slight_smile:
testing.
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3911/changes&gt;
