See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3928/>
[...truncated 48415 lines...]
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/src/main/resources>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-3,5,main] waiting
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] waiting
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] waiting
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.513 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.101 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core>
[INFO] Copying 10 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/resources>
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 118 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java>:\[18,25\] cannot find symbol
symbol : class Element
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java>:\[113,35\] cannot find symbol
location: class org.geoserver.wps.gs.GridProcess.GridFeatureBuilderImpl
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java>:\[128,34\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java>:\[131,40\] cannot find symbol
symbol : method getCenter()
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java>:\[132,40\] cannot find symbol
[INFO] Total time: 11 minutes 29 seconds
[INFO] Finished at: Wed May 11 08:34:13 UTC 2011
[INFO] Final Memory: 83M/331M
