[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4009
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4009/changes&gt;
Changes:
[groldan] reminder to self: IOException(Throwable) is a Java6 thing...
[groldan] Community cleanup, remove empty directories (leftovers of git svn dcommit again?)
[groldan] Community cleanup, remove translator module
[groldan] delete empty directories that git svn dcommit leaves floating around
[groldan] rename package
[groldan] GeoSearch module revamped
[groldan] avoid possible NPE
[...truncated 46795 lines...]
    </xsd:complexType>
    <xsd:element name="MappedFeature" substitutionGroup="gml:_Feature" type="gsml:MappedFeatureType"/>
</xsd:schema>
May 25, 2011 6:06:42 AM org.geoserver.test.SampleDataAccessWfsTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
    timeStamp="2011-05-25T06:06:41.808Z"
    xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.example.org/sample-data-access/GeoSciML-lite&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.example.org/sample-data-access/GeoSciML-lite http://localhost:8080/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=gsml%3AMappedFeature http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMembers>
        <gsml:MappedFeature gml:id="mf1">
            <gml:description>GUNTHORPE FORMATION</gml:description>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="mf1.spec">
                    <gml:description>Gunthorpe specification description</gml:description>
                </gsml:GeologicUnit>
            </gsml:specification>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
        </gsml:MappedFeature>
        <gsml:MappedFeature gml:id="mf2">
            <gml:description>MERCIA MUDSTONE GROUP</gml:description>
                <gsml:GeologicUnit gml:id="mf2.spec">
                    <gml:description>Mercia specification description</gml:description>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.3 52.5 -1.3 52.6 -1.2 52.6 -1.2 52.5 -1.3 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
    </gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.003 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde&gt;
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.data.store.arcsde.ArcSDECoverageStoreEditPanelTest
25 May 06:06:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock8980962484633543486data&gt;
25 May 06:06:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock4100581424718930789data&gt;
25 May 06:06:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock4083247590482907578data&gt;
25 May 06:06:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock2099077470908856578data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock6857032978757350631data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.973 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoSearch Index Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch&gt;
[INFO] Copying 3 resources
[INFO] Copying 4 resources
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/surefire-reports&gt;
T E S T S
Running org.geoserver.geosearch.rest.SiteMapTest
25 May 06:06:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/./target/mock3605245347928185498data&gt;
[Fatal Error] :-1:-1: Premature end of file.
Tests run: 3, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 9.984 sec <<< FAILURE!
Results :
Tests in error:
  testSiteMap(org.geoserver.geosearch.rest.SiteMapTest)
  testKmlUrls(org.geoserver.geosearch.rest.SiteMapTest)
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 11 minutes 7 seconds
[INFO] Finished at: Wed May 25 06:07:07 UTC 2011
[INFO] Final Memory: 73M/281M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4010/changes&gt;
