See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4024/changes>
Changes:
[aaime] [GEOS-4521] WPS DescribeProcess output is not valid
[aaime] [GEOS-4580] GeoTiff file handles are not closed immediately, can accumulate and result in OS level errors
[...truncated 49832 lines...]
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:950)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:315)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:389)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:782)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:799)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:639)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:730)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:468)
at org.geotools.referencing.CRS.decode(CRS.java:396)
at org.geoserver.wps.ppio.CoordinateReferenceSystemPPIO.decode(CoordinateReferenceSystemPPIO.java:29)
at org.geoserver.wps.Execute.parseProcessInputs(Execute.java:380)
... 54 more
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.259 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
28 May 09:57:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock8933806086603852740data>
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs" xmlns:feature="http://cite.opengeospatial.org/gmlsf" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc">
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#26713">
<gml:coord>
<gml:X>591587.74604609</gml:X>
<gml:Y>4916224.777098622</gml:Y>
</gml:coord>
<gml:coord>
<gml:X>599657.4754089377</gml:X>
<gml:Y>4925860.249209468</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<feature:restricted fid="restricted.1290183938662">
<gml:boundedBy>
<gml:coord>
<gml:Y>4925296.068594761</gml:Y>
</gml:coord>
<gml:coord>
<gml:X>592560.7822126707</gml:X>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<feature:z_the_geom>
<gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#26713">
<gml:polygonMember>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>591954.3359385637,4925859.483293386 591957.3824433011,4925860.249209468 591996.9678179699,4925842.719067588 592066.2434228227,4925813.759259981 592235.2420918944,4925738.302342218 592551.8201372348,4925671.437550496 592560.7822126707,4925327.905382568 591595.3483009903,4925296.068594761 591593.0136062276,4925322.439424193 591587.74604609,4925412.531691931 591618.2329452335,4925451.495549678 591630.4333543724,4925475.174502224 591801.1266256558,4925645.575178106 591930.6806241288,4925789.2201092215 591954.3359385637,4925859.483293386</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</feature:z_the_geom>
<feature:z_cat>1</feature:z_cat>
</feature:restricted>
</gml:featureMember>
<gml:featureMember>
<feature:restricted fid="restricted.1290183938665">
<gml:boundedBy>
<gml:coord>
<gml:X>593157.5354776975</gml:X>
<gml:Y>4923980.52355841</gml:Y>
</gml:coord>
<gml:coord>
<gml:X>593538.9831172063</gml:X>
<gml:Y>4925012.3979659295</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:polygonMember>
<gml:Polygon>
<gml:LinearRing>
<gml:coordinates>593183.6607205212,4923980.52355841 593157.5354776975,4925010.357654894 593538.9831172063,4925012.3979659295 593486.3194805589,4924758.104346828 593396.420353626,4924644.995457535 593390.2700977508,4924528.182140326 593279.007632818,4924326.4864263795 593256.9034614969,4924278.360480662 593221.8366082398,4924192.04550526 593198.169007116,4924063.757134442 593194.3458770494,4924031.687860058 593183.6607205212,4923980.52355841</gml:coordinates>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
<feature:z_cat>2</feature:z_cat>
<gml:featureMember>
<feature:restricted fid="restricted.1290183938666">
<gml:boundedBy>
<gml:coord>
<gml:X>598239.5942270659</gml:X>
</gml:coord>
<gml:coord>
<gml:Y>4917345.075533595</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:polygonMember>
<gml:Polygon>
<gml:LinearRing>
<gml:coordinates>598239.5942270659,4917334.785918331 599645.0893316591,4917345.075533595 599657.4754089377,4916247.277528859 598255.0195882423,4916224.777098622 598239.5942270659,4917334.785918331</gml:coordinates>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
<feature:z_cat>4</feature:z_cat>
<feature:count>1</feature:count>
<feature:min>84.0</feature:min>
<feature:max>84.0</feature:max>
<feature:sum>84.0</feature:sum>
<feature:avg>84.0</feature:avg>
<feature:stddev>0.0</feature:stddev>
<gml:featureMember>
<feature:restricted fid="restricted.1290183938667">
<gml:boundedBy>
<gml:coord>
<gml:X>592250.9171658278</gml:X>
<gml:Y>4916851.195066947</gml:Y>
</gml:coord>
<gml:coord>
<gml:X>597086.9686143089</gml:X>
<gml:Y>4921789.551205</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:polygonMember>
<gml:Polygon>
<gml:LinearRing>
<gml:coordinates>592316.9379796328,4921789.551205 595825.0954050707,4921744.536515899 595885.9596931553,4921724.645000904 595988.6597380087,4921687.164865309 596085.2476595924,4921639.762469891 596199.3035518276,4921572.496462965 596425.0407301437,4921395.970557282 596646.8773303393,4921175.924634823 596705.3044231973,4921085.024251698 596895.7087137242,4920764.209535123 597037.3181371056,4920411.356964448 597086.9686143089,4920134.155276274 597086.9455551769,4920123.465548163 595404.9389344064,4916851.195066947 595299.9499316034,4916886.386015123 595162.2497092936,4916933.814845423 594983.526128624,4917022.501919034 594829.906966761,4917102.010213899 594395.0453582691,4917391.676438842 594318.2555423079,4917440.593210369 594052.0932835294,4917582.785221043 593703.9205438099,4917824.291862512 593327.876386339,4918204.019530202 592902.7306171365,4918762.450187511 592799.5541783689,4918932.025310009 592746.4663403123,4919027.503578438 592681.9715953676,4919129.097605954 592425.6305890534,4919588.921377501 592354.4073250518,4919747.786211425 592321.8954023286,4919852.413886508 592250.9171658278,4920477.809486801 592252.310983779,4920771.012968304 592264.8066111131,4921269.605086448 592316.9379796328,4921789.551205</gml:coordinates>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
<feature:z_cat>3</feature:z_cat>
<feature:count>23</feature:count>
<feature:min>32.0</feature:min>
<feature:max>81.0</feature:max>
<feature:sum>1331.0</feature:sum>
<feature:avg>57.869565217391305</feature:avg>
<feature:stddev>15.120686514855372</feature:stddev>
</wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.816 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
28 May 09:58:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock7571106338452799074data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock3345999647770876041data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock7007554831026598632data>
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.88 sec <<< FAILURE!
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
28 May 09:58:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock4343335163046285547data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.044 sec
Running org.geoserver.wps.gs.StoreCoverageTest
28 May 09:58:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock8996369042585185612data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.434 sec
Running org.geoserver.wps.gs.AggregateProcessTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock6905143277853461221data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock4041046529511949931data>
28 May 09:58:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock6909471820422550838data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock4867853209772768809data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock1289587751021569134data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock5878300223113741316data>
28 May 09:58:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/./target/mock3089708729918395676data>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.844 sec
Results :
Failed tests:
testGetBuffer(org.geoserver.wps.DescribeProcessTest)
testPostBuffer(org.geoserver.wps.DescribeProcessTest)
testRasterToVector(org.geoserver.wps.DescribeProcessTest)
testBounds(org.geoserver.wps.DescribeProcessTest)
testDescribeBuffer(org.geoserver.wps.jts.GeometryProcessWPSTest)
Tests run: 114, Failures: 5, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[INFO] Total time: 13 minutes 27 seconds
[INFO] Finished at: Sat May 28 09:58:04 UTC 2011
[INFO] Final Memory: 85M/349M
