See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4082/changes>
Changes:
[aaime] [GEOS-3754] Add support for TIME and ELEVATION parameters, vector part
[...truncated 20888 lines...]
<Service>
<Name>OGC:WMS</Name>
<Title>My GeoServer WMS</Title>
<Abstract>
This is a description of your Web Map Server.
</Abstract>
<KeywordList>
<Keyword>WFS</Keyword>
<Keyword>WMS</Keyword>
<Keyword>GEOSERVER</Keyword>
</KeywordList>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoserver.sourceforge.net/html/index.php" xlink:type="simple"/>
<ContactInformation>
<ContactPersonPrimary>
<ContactPerson>Andrea Aime</ContactPerson>
<ContactOrganization/>
</ContactPersonPrimary>
<ContactPosition/>
<ContactAddress>
<AddressType/>
<Address/>
<City/>
<StateOrProvince/>
<PostCode/>
<Country/>
</ContactAddress>
<ContactVoiceTelephone/>
<ContactFacsimileTelephone/>
<ContactElectronicMailAddress/>
</ContactInformation>
<Fees>NONE</Fees>
<AccessConstraints>NONE</AccessConstraints>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="src/test/resources/geoserver/wms?SERVICE=WMS&" xlink:type="simple"/>
</Get>
<Post>
</Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/png</Format>
<Format>application/atom xml</Format>
<Format>application/atom+xml</Format>
<Format>application/openlayers</Format>
<Format>application/pdf</Format>
<Format>application/rss xml</Format>
<Format>application/rss+xml</Format>
<Format>application/vnd.google-earth.kml</Format>
<Format>application/vnd.google-earth.kml xml</Format>
<Format>application/vnd.google-earth.kml+xml</Format>
<Format>application/vnd.google-earth.kml+xml;mode=networklink</Format>
<Format>application/vnd.google-earth.kmz</Format>
<Format>application/vnd.google-earth.kmz xml</Format>
<Format>application/vnd.google-earth.kmz+xml</Format>
<Format>application/vnd.google-earth.kmz;mode=networklink</Format>
<Format>atom</Format>
<Format>image/geotiff</Format>
<Format>image/geotiff8</Format>
<Format>image/gif</Format>
<Format>image/jpeg</Format>
<Format>image/png8</Format>
<Format>image/svg</Format>
<Format>image/svg xml</Format>
<Format>image/svg+xml</Format>
<Format>image/tiff</Format>
<Format>image/tiff8</Format>
<Format>kml</Format>
<Format>kmz</Format>
<Format>openlayers</Format>
<Format>rss</Format>
<DCPType>
<HTTP>
<Get>
</Get>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<Format>application/vnd.ogc.gml/3.1.1</Format>
<Format>text/html</Format>
<DCPType>
<HTTP>
<Get>
</Get>
<Post>
</Post>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<DCPType>
<HTTP>
<Get>
</Get>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
<Get>
</Get>
</HTTP>
</DCPType>
</GetLegendGraphic>
<GetStyles>
<Format>application/vnd.ogc.sld+xml</Format>
<DCPType>
<HTTP>
<Get>
</Get>
</HTTP>
</DCPType>
</GetStyles>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
</Exception>
<VendorSpecificCapabilities/>
<UserDefinedSymbolization RemoteWFS="1" SupportSLD="1" UserLayer="1" UserStyle="1"/>
<Layer noSubsets="0" opaque="0" queryable="0">
<Abstract>
</Abstract>
<!--Limited list of EPSG projections:-->
<SRS>EPSG:4326</SRS>
<LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Layer noSubsets="0" opaque="0" queryable="1">
<Name>sf:TimeElevation</Name>
<Title>TimeElevation</Title>
<Abstract>abstract about TimeElevation</Abstract>
<KeywordList>
<Keyword>TimeElevation</Keyword>
</KeywordList>
<!--WKT definition of this CRS:
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]-->
<BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Dimension name="elevation" units="EPSG:5030"/>
<Extent default="0.0" name="elevation" nearestValue="0">0.0/3.0/1.0</Extent>
<Style>
<Name>TimeElevation</Name>
<Title/>
<Abstract/>
<LegendURL height="20" width="20">
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="src/test/resources/geoserver/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=TimeElevation" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
09 Jun 14:41:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock6639083331846075053data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock5538742542554496982data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7626455768472727412data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1867014802367300874data>
Tests run: 8, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 1.668 sec <<< FAILURE!
Running org.geoserver.kml.KMZMapProducerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock7068067752819844009data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
09 Jun 14:42:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock514370739573891843data>
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.728 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
09 Jun 14:42:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock1609252821856473725data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Failed tests:
testTimeList(org.geoserver.wms.wms_1_3.DimensionsCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsCapabilitiesTest)
testTimeElevation(org.geoserver.wms.wms_1_3.DimensionsCapabilitiesTest)
testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsCapabilitiesTest)
Tests run: 307, Failures: 7, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 5 minutes 13 seconds
[INFO] Finished at: Thu Jun 09 14:42:02 UTC 2011
[INFO] Final Memory: 62M/268M
