[Geoserver-devel] Build failed in Hudson: geoserver-trunk #41
See http://geo.openplans.org:8080/hudson/job/geoserver-trunk/41/changes
[...truncated 4315 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:879)
03 Jan 17:14:27 ERROR [geoserver.ows] -
java.lang.NoClassDefFoundError: org/geotools/referencing/wkt/Formatter
  at org.geotools.referencing.wkt.Formattable.toWKT(Formattable.java:164)
  at org.geotools.referencing.wkt.Formattable.toString(Formattable.java:80)
  at java.lang.String.valueOf(String.java:2615)
  at java.lang.StringBuffer.append(StringBuffer.java:220)
  at org.geotools.feature.GeometryAttributeImpl.toString(GeometryAttributeImpl.java:189)
  at java.util.AbstractCollection.toString(AbstractCollection.java:454)
  at org.geotools.feature.AttributeImpl.toString(AttributeImpl.java:115)
  at org.eclipse.emf.common.util.BasicEList.toString(BasicEList.java:1214)
  at net.opengis.wfs.impl.InsertElementTypeImpl.toString(InsertElementTypeImpl.java:423)
  at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$BasicFeatureMapEntry.toString(EStructuralFeatureImpl.java:2899)
  at java.lang.StringBuilder.append(StringBuilder.java:116)
  at org.geoserver.ows.util.EMFLogger.log(EMFLogger.java:75)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:47)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.transaction(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.geoserver.test.GeoServerTestSupport.dispatch(GeoServerTestSupport.java:618)
  at org.geoserver.test.GeoServerTestSupport.post(GeoServerTestSupport.java:328)
  at org.geoserver.test.GeoServerTestSupport.postAsDOM(GeoServerTestSupport.java:429)
  at org.geoserver.test.GeoServerTestSupport.postAsDOM(GeoServerTestSupport.java:412)
  at org.geoserver.wfs.TransactionListenerTest.testInsert(TransactionListenerTest.java:76)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at sun.reflect.GeneratedMethodAccessor92.invoke(Unknown Source)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:138)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:125)
  at org.apache.maven.surefire.Surefire.run(Surefire.java:132)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:308)
Tests run: 3, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 1.506 sec <<< FAILURE!
Running org.geoserver.wfs.DescribeFeatureTest
03 Jan 17:14:28 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
03 Jan 17:14:28 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.Transaction.getDatastoreTransaction Transaction'
03 Jan 17:14:29 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.796 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.838 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.161 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.556 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.169 sec <<< FAILURE!
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.08 sec
Results :
Failed tests:
  testLock(org.geoserver.wfs.v1_1.LockFeatureTest)
  testUpdate(org.geoserver.wfs.GeometrylessTest)
  testGetFeature10(org.geoserver.wfs.GeometrylessTest)
  testGetFeatureReproject10(org.geoserver.wfs.GeometrylessTest)
  testGetFeature11(org.geoserver.wfs.GeometrylessTest)
  testGetFeatureReproject11(org.geoserver.wfs.GeometrylessTest)
  testGetFeatureReprojectPost(org.geoserver.wfs.GeometrylessTest)
  testDelete(org.geoserver.wfs.GeometrylessTest)
  testInsert(org.geoserver.wfs.GeometrylessTest)
  testGet(org.geoserver.wfs.GetFeatureTest)
  testGetPropertyNameEmpty(org.geoserver.wfs.GetFeatureTest)
  testGetPropertyNameStar(org.geoserver.wfs.GetFeatureTest)
  testPost(org.geoserver.wfs.GetFeatureTest)
  testPostWithFilter(org.geoserver.wfs.GetFeatureTest)
  testLax(org.geoserver.wfs.GetFeatureTest)
  testLockActionSomeAlreadyLocked(org.geoserver.wfs.LockFeatureTest)
  testDeleteWithoutLockId(org.geoserver.wfs.LockFeatureTest)
  testUpdateWithLockId(org.geoserver.wfs.LockFeatureTest)
  testUpdateLockedFeatureWithLockId(org.geoserver.wfs.GetFeatureWithLockTest)
  testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.GetFeatureWithLockTest)
  testGet(org.geoserver.wfs.v1_1.GetFeatureTest)
  testGetPropertyNameEmpty(org.geoserver.wfs.v1_1.GetFeatureTest)
  testGetPropertyNameStar(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPost(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostFormEncoded(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithFailingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testResultTypeHitsGet(org.geoserver.wfs.v1_1.GetFeatureTest)
  testResultTypeHitsPost(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithSRS(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithSillyLiteral(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithGmlObjectId(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithBoundsEnabled(org.geoserver.wfs.v1_1.GetFeatureTest)
  testAfterFeatureTypeAdded(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithGMLProperties(org.geoserver.wfs.v1_1.GetFeatureTest)
  testInsert1(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithBoundedBy(org.geoserver.wfs.v1_1.TransactionTest)
  testInsert2(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateForcedSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
  test(org.geoserver.wfs.v1_1.GetFeatureWithLockTest)
  testUpdate(org.geoserver.wfs.TransactionTest)
  testInsertWithBoundedBy(org.geoserver.wfs.TransactionTest)
  testDelete(org.geoserver.wfs.TransactionTest)
  testInsert(org.geoserver.wfs.TransactionTest)
  testGML2(org.geoserver.wfs.xml.GMLOutputFormatTest)
  testGML3(org.geoserver.wfs.xml.GMLOutputFormatTest)
  testUpdate(org.geoserver.wfs.TransactionListenerTest)
  testDelete(org.geoserver.wfs.TransactionListenerTest)
  testInsert(org.geoserver.wfs.TransactionListenerTest)
Tests in error:
  testGet(org.geoserver.wfs.response.GeoJSONTest)
  testPost(org.geoserver.wfs.response.GeoJSONTest)
  testGeometryCollection(org.geoserver.wfs.response.GeoJSONTest)
  testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.GetFeatureWithLockTest)
  testBboxNoReprojection(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testBboxReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testBboxReprojectUnreferencedProperty(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsUnreferencedGeometry(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsUnreferencedProperty(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testSingle(org.geoserver.wfs.xml.GML3FeatureProducerTest)
  testMultipleSameNamespace(org.geoserver.wfs.xml.GML3FeatureProducerTest)
  testMultipleDifferentNamespace(org.geoserver.wfs.xml.GML3FeatureProducerTest)
  testGetFeatureGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeaturePost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testInsertSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testInsertGeomSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdate(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdateReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdateReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureGet(org.geoserver.wfs.ReprojectionTest)
  testGetFeaturePost(org.geoserver.wfs.ReprojectionTest)
  testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.ReprojectionTest)
  testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.ReprojectionTest)
  testInsertSrsName(org.geoserver.wfs.ReprojectionTest)
  testInsertGeomSrsName(org.geoserver.wfs.ReprojectionTest)
  testUpdate(org.geoserver.wfs.ReprojectionTest)
  testReprojectNullGeometries(org.geoserver.wfs.ReprojectionTest)
  testNoNativeProjection(org.geoserver.wfs.response.ShapeZipTest)
Tests run: 124, Failures: 56, Errors: 35, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://geo.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 45 seconds
[INFO] Finished at: Thu Jan 03 17:14:38 GMT-05:00 2008
[INFO] Final Memory: 54M/237M
See http://geo.openplans.org:8080/hudson/job/geoserver-trunk/42/changes
