See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4140/>
[...truncated 1209 lines...]
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Jun 20, 2011 1:11:22 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 32, Failures: 0, Errors: 32, Skipped: 0, Time elapsed: 10.263 sec <<< FAILURE!
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.28 sec <<< FAILURE!
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.09 sec <<< FAILURE!
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.013 sec <<< FAILURE!
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.153 sec <<< FAILURE!
Running org.geoserver.catalog.impl.CatalogImplTest
Jun 20, 2011 1:11:31 PM org.geoserver.catalog.impl.CatalogImpl event
WARNING: Catalog listener threw exception handling event.
java.lang.RuntimeException
at org.geoserver.catalog.impl.CatalogImplTest$ExceptionThrowingListener.handleAddEvent(CatalogImplTest.java:1342)
at org.geoserver.catalog.impl.CatalogImpl.event(CatalogImpl.java:1157)
at org.geoserver.catalog.impl.CatalogImpl.fireAdded(CatalogImpl.java:1121)
at org.geoserver.catalog.impl.CatalogImpl.added(CatalogImpl.java:1110)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:925)
at org.geoserver.catalog.impl.CatalogImplTest.testExceptionThrowingListener(CatalogImplTest.java:1239)
at sun.reflect.GeneratedMethodAccessor43.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.418 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 1.223 sec <<< FAILURE!
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 1.328 sec <<< FAILURE!
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.696 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.025 sec <<< FAILURE!
Running org.geoserver.config.util.XStreamPersisterTest
Jun 20, 2011 1:11:36 PM org.geoserver.config.util.XStreamPersister$ResourceInfoConverter doUnmarshal
INFO: Loaded feature type 'ft', disabled
Jun 20, 2011 1:11:36 PM org.geoserver.config.util.XStreamPersister$StoreInfoConverter doUnmarshal
INFO: Loaded store 'bar', disabled
INFO: Loaded store 'foo', disabled
Jun 20, 2011 1:11:36 PM org.geoserver.config.util.XStreamPersister$SpaceMapConverter unmarshal
INFO: Loading namespace 'acme'
INFO: Loading workspace 'foo'
INFO: Loaded resource 'wmsLayer', disabled
Tests run: 15, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.625 sec <<< FAILURE!
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Jun 20, 2011 1:11:36 PM org.geoserver.security.impl.DataAccessRuleDAO parseDataAccessRule
WARNING: Namespace/Workspace topp is unknown in rule topp.*.r=*
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.w=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.r=READER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.r=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
Jun 20, 2011 1:11:37 PM org.geoserver.security.impl.DataAccessRuleDAO loadRules
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.079 sec
Running org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.005 sec <<< FAILURE!
Running org.geoserver.config.GeoServerPropertyConfigurerTest
20 Jun 13:11:37 INFO [config.GeoServerPropertyConfigurer] - Loading properties file from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/foo.properties\]>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.139 sec
Results :
Tests in error:
testForce(org.vfny.geoserver.ProjectionPolicyTest)
testReproject(org.vfny.geoserver.ProjectionPolicyTest)
testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest)
testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
testOverride(org.vfny.geoserver.crs.OvverideCRSTest)
testFeatureTypeCacheInstance(org.geoserver.catalog.ResourcePoolTest)
testAttributeCache(org.geoserver.catalog.ResourcePoolTest)
testCacheClearing(org.geoserver.catalog.ResourcePoolTest)
testDispose(org.geoserver.catalog.ResourcePoolTest)
testLRU(org.geoserver.catalog.ResourcePoolTest)
testGeoServerReload(org.geoserver.catalog.ResourcePoolTest)
testConfigureFeatureTypeCacheSize(org.geoserver.catalog.ResourcePoolTest)
testCatalogUpdates(org.geoserver.config.UpdateSequenceListenerTest)
testServiceUpdates(org.geoserver.config.UpdateSequenceListenerTest)
testCascadeLayer(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
testCascadeStore(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
testCascadeWorkspace(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
testCascadeStyle(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
testCascadeStyle(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
testFullAccess(org.geoserver.security.impl.SecureCatalogIntegrationTest)
testCannotRead(org.geoserver.security.impl.SecureCatalogIntegrationTest)
testCannotWrite(org.geoserver.security.impl.SecureCatalogIntegrationTest)
test(org.geoserver.template.GeoServerTemplateLoaderTest)
testRemoteType(org.geoserver.template.GeoServerTemplateLoaderTest)
testAddWorkspace(org.geoserver.config.GeoServerPersisterTest)
testRemoveWorkspace(org.geoserver.config.GeoServerPersisterTest)
testAddDataStore(org.geoserver.config.GeoServerPersisterTest)
testRemoveDataStore(org.geoserver.config.GeoServerPersisterTest)
testModifyDataStore(org.geoserver.config.GeoServerPersisterTest)
testChangeDataStoreWorkspace(org.geoserver.config.GeoServerPersisterTest)
testAddFeatureType(org.geoserver.config.GeoServerPersisterTest)
testAddCoverage(org.geoserver.config.GeoServerPersisterTest)
testAddWMSLayer(org.geoserver.config.GeoServerPersisterTest)
testRemoveFeatureType(org.geoserver.config.GeoServerPersisterTest)
testRemoveWMSLayer(org.geoserver.config.GeoServerPersisterTest)
testModifyFeatureType(org.geoserver.config.GeoServerPersisterTest)
testAddLayer(org.geoserver.config.GeoServerPersisterTest)
testRemoveLayer(org.geoserver.config.GeoServerPersisterTest)
testModifyLayer(org.geoserver.config.GeoServerPersisterTest)
testAddStyle(org.geoserver.config.GeoServerPersisterTest)
testModifyStyle(org.geoserver.config.GeoServerPersisterTest)
testRemoveStyle(org.geoserver.config.GeoServerPersisterTest)
testAddWMSStore(org.geoserver.config.GeoServerPersisterTest)
testModifyGlobal(org.geoserver.config.GeoServerPersisterTest)
testDefaultWorkspace(org.geoserver.config.GeoServerPersisterTest)
testAddCoverageStore(org.geoserver.config.GeoServerPersisterTest)
testModifyCoverageStore(org.geoserver.config.GeoServerPersisterTest)
testRemoveCoverageStore(org.geoserver.config.GeoServerPersisterTest)
testModifyCoverage(org.geoserver.config.GeoServerPersisterTest)
testRemoveCoverage(org.geoserver.config.GeoServerPersisterTest)
testModifyWMSStore(org.geoserver.config.GeoServerPersisterTest)
testRemoveWMSStore(org.geoserver.config.GeoServerPersisterTest)
testModifyWMSLayer(org.geoserver.config.GeoServerPersisterTest)
testAddLayerGroup(org.geoserver.config.GeoServerPersisterTest)
testModifyLayerGroup(org.geoserver.config.GeoServerPersisterTest)
testRemoveLayerGroup(org.geoserver.config.GeoServerPersisterTest)
testGlobal(org.geoserver.template.GeoServerTemplateLoader2Test)
testRemoteType(org.geoserver.template.GeoServerTemplateLoader2Test)
testRelativeToFeatureType(org.geoserver.template.GeoServerTemplateLoader2Test)
testRelativeToStore(org.geoserver.template.GeoServerTemplateLoader2Test)
testRelativeToWorkspace(org.geoserver.template.GeoServerTemplateLoader2Test)
testBasic(org.geoserver.ows.URLManglersTest)
testKVP(org.geoserver.ows.URLManglersTest)
testProxyBase(org.geoserver.ows.URLManglersTest)
testMissingFeatureTypes(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
testMissingCoverages(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
testCRSPrefix(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
testNoMapping(org.geoserver.catalog.SchemaMappingTest)
testXsdMapping(org.geoserver.catalog.SchemaMappingTest)
testXmlMapping(org.geoserver.catalog.SchemaMappingTest)
testBasic(org.geoserver.ows.CustomManglerTest)
testKVP(org.geoserver.ows.CustomManglerTest)
testValid(org.vfny.geoserver.util.SLDValidatorTest)
testInvalid(org.vfny.geoserver.util.SLDValidatorTest)
testContextStartup(org.geoserver.vfny.global.TolerantStartupTest)
testGobalContactDefault(org.geoserver.config.util.XStreamPersisterTest)
testChangeWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
testChangeNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
testChangeDefaultWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
testChangeDefaultNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
testChangeNamespaceURI(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
Tests run: 268, Failures: 0, Errors: 86, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 2 minutes 10 seconds
[INFO] Finished at: Mon Jun 20 13:11:37 UTC 2011
[INFO] Final Memory: 57M/390M
