[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4197
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4197/changes&gt;
Changes:
[aaime] [GEOS-4656] Configuring a mosaic with a lot of files can result in "too many open files"
[...truncated 619 lines...]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.ows:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 83 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes&gt;
[INFO] Copying 4 resources
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.145 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Jun 30, 2011 2:22:05 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.282 sec
Running org.geoserver.ows.kvp.ElevationKvpParserTest
Jun 30, 2011 2:22:05 PM org.geoserver.ows.kvp.ElevationKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Jun 30, 2011 2:22:06 PM org.geoserver.ows.kvp.TimeKvpParser parse
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.ows.DispatcherTest
Jun 30, 2011 2:22:06 PM org.geoserver.platform.GeoServerExtensions checkContext
Jun 30, 2011 2:22:06 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Thu Jun 30 14:22:06 UTC 2011]; root of context hierarchy
Jun 30, 2011 2:22:06 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Jun 30, 2011 2:22:06 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.433 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Results :
Tests run: 34, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main&gt;
[INFO] Copying 28 resources
[INFO] Copying 1 resource
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 301 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/CatalogBuilder.java&gt;:\[38,35\] package org.geotools.gce.imagemosaic does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/CatalogBuilder.java&gt;:\[39,35\] package org.geotools.gce.imagemosaic does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/CatalogBuilder.java&gt;:\[711,50\] package ImageMosaicFormat does not exist
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Thu Jun 30 14:22:28 UTC 2011
[INFO] Final Memory: 58M/411M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4198/changes&gt;
Changes:
[aaime] Fixing the build
[...truncated 14562 lines...]
Jun 30, 2011 2:31:16 PM org.geotools.gce.imagemosaic.catalogbuilder.CatalogBuilder fireEvent
INFO: Now indexing file tile_0856.tiff
INFO: Now indexing file tile_0113.tiff
INFO: Now indexing file tile_1024.tiff
INFO: Now indexing file tile_0746.tiff
INFO: Now indexing file tile_0407.tiff
INFO: Now indexing file tile_0298.tiff
INFO: Now indexing file tile_0556.tiff
INFO: Now indexing file tile_0549.tiff
INFO: Now indexing file tile_0688.tiff
INFO: Now indexing file tile_0439.tiff
INFO: Now indexing file tile_0466.tiff
INFO: Now indexing file tile_0389.tiff
INFO: Now indexing file tile_0775.tiff
INFO: Now indexing file tile_0939.tiff
INFO: Now indexing file tile_0998.tiff
INFO: Now indexing file tile_0170.tiff
INFO: Now indexing file tile_0534.tiff
INFO: Now indexing file tile_0898.tiff
INFO: Now indexing file tile_0083.tiff
INFO: Now indexing file tile_0828.tiff
INFO: Now indexing file tile_0593.tiff
INFO: Now indexing file tile_0738.tiff
INFO: Now indexing file tile_0011.tiff
INFO: Now indexing file tile_0696.tiff
INFO: Now indexing file tile_0332.tiff
INFO: Now indexing file tile_0628.tiff
INFO: Now indexing file tile_0339.tiff
INFO: Now indexing file tile_0477.tiff
INFO: Now indexing file tile_0194.tiff
INFO: Now indexing file tile_0022.tiff
INFO: Now indexing file tile_1020.tiff
INFO: Now indexing file tile_0536.tiff
INFO: Now indexing file tile_0691.tiff
INFO: Now indexing file tile_0975.tiff
INFO: Now indexing file tile_0051.tiff
INFO: Now indexing file tile_0577.tiff
INFO: Now indexing file tile_0684.tiff
INFO: Now indexing file tile_0686.tiff
INFO: Now indexing file tile_0034.tiff
INFO: Now indexing file tile_0216.tiff
INFO: Now indexing file tile_0009.tiff
INFO: Now indexing file tile_0036.tiff
INFO: Now indexing file tile_0977.tiff
INFO: Now indexing file tile_0946.tiff
INFO: Now indexing file tile_0097.tiff
INFO: Now indexing file tile_0928.tiff
INFO: Now indexing file tile_0832.tiff
INFO: Now indexing file tile_0345.tiff
INFO: Now indexing file tile_0850.tiff
INFO: Now indexing file tile_0212.tiff
INFO: Now indexing file tile_0316.tiff
INFO: Now indexing file tile_0811.tiff
INFO: Now indexing file tile_0463.tiff
INFO: Now indexing file tile_0867.tiff
INFO: Now indexing file tile_0024.tiff
INFO: Now indexing file tile_0774.tiff
INFO: Now indexing file tile_0380.tiff
INFO: Now indexing file tile_0579.tiff
INFO: Now indexing file tile_0288.tiff
INFO: Now indexing file tile_0182.tiff
INFO: Now indexing file tile_0222.tiff
INFO: Now indexing file tile_0099.tiff
INFO: Now indexing file tile_0121.tiff
INFO: Now indexing file tile_0980.tiff
INFO: Now indexing file tile_0543.tiff
INFO: Now indexing file tile_0343.tiff
INFO: Now indexing file tile_0259.tiff
INFO: Now indexing file tile_0680.tiff
INFO: Now indexing file tile_0551.tiff
INFO: Now indexing file tile_0954.tiff
INFO: Now indexing file tile_0912.tiff
Jun 30, 2011 2:31:17 PM org.geotools.data.shapefile.indexed.ShapeFileIndexer buildQuadTree
INFO: Optimizing the tree (this might take some time)
INFO: Tree optimized
Jun 30, 2011 2:31:17 PM org.geotools.gce.imagemosaic.catalogbuilder.CatalogBuilder fireEvent
INFO: Creating final properties file
Jun 30, 2011 2:31:17 PM org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog extractBasicProperties
WARNING: BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: largeMosaic
Jun 30, 2011 2:31:18 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-7b1ca289:130e0f5a27a:-5158'
INFO: Disposing datastore 'DataStoreInfoImpl-7b1ca289:130e0f5a27a:-5157'
INFO: Disposing datastore 'DataStoreInfoImpl-7b1ca289:130e0f5a27a:-515a'
INFO: Disposing datastore 'DataStoreInfoImpl-7b1ca289:130e0f5a27a:-5159'
Jun 30, 2011 2:31:18 PM org.geoserver.catalog.ResourcePool$CoverageHintReaderCache dispose
INFO: Disposing grid coverage reader 'DEM'
INFO: Disposing grid coverage reader 'largeMosaic'
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.894 sec
Running org.geoserver.config.util.XStreamPersisterTest
Jun 30, 2011 2:31:18 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.098 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 9, Skipped: 0, Time elapsed: 0.019 sec <<< FAILURE!
Running org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Running org.geoserver.config.GeoServerPropertyConfigurerTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.005 sec <<< FAILURE!
Results :
Tests in error:
  testWideOpen(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testLockedDown(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testPublicRead(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testComplex(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testDefaultMode(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testHideMode(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testChallengeMode(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testMixedMode(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testUnknownMode(org.geoserver.security.impl.DefaultDataAccessManagerAuthTest)
  testChangeWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespaceURI(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testDefaults(org.geoserver.config.GeoServerPropertyConfigurerTest)
  testUserSpecified(org.geoserver.config.GeoServerPropertyConfigurerTest)
Tests run: 274, Failures: 0, Errors: 16, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 13 seconds
[INFO] Finished at: Thu Jun 30 14:31:19 UTC 2011
[INFO] Final Memory: 57M/401M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4199/changes&gt;
