[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4229
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4229/&gt;
[...truncated 24445 lines...]
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows src/test/resources/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
  <ows:Exception exceptionCode="InvalidParameterValue" locator="service">
    <ows:ExceptionText>No service: ( ows )</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
08 Jul 11:56:18 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( ows )
  at org.geoserver.ows.Dispatcher.service(Dispatcher.java:410)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:218)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1217)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1236)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:593)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:576)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:561)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:846)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:810)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestMandatoryRequestParameter(CapabilitiesSystemTest.java:211)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor214.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 2)
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:323)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:67)
  at sun.reflect.GeneratedMethodAccessor231.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy15.getCapabilities(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor230.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:246)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current sever updateSequence
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:263)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.843 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
08 Jul 11:56:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/./target/mock8981277975226292317data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Results :
Tests in error:
  testDefaultStyle(org.geoserver.wms.map.GIFMapResponseTest)
  testBlueLake(org.geoserver.wms.map.GIFMapResponseTest)
  testDefaultStyle(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  testBlueLake(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
  testFilter(org.geoserver.wms.georss.RSSGeoRSSTransformerTest)
  testLatLongInternal(org.geoserver.wms.georss.RSSGeoRSSTransformerTest)
  testSimpleInternal(org.geoserver.wms.georss.RSSGeoRSSTransformerTest)
  testReproject(org.geoserver.wms.georss.RSSGeoRSSTransformerTest)
  testRasterTransformerInline(org.geoserver.kml.KMLTransformerTest)
  testRasterTransformerNotInline(org.geoserver.kml.KMLTransformerTest)
  testRasterPlacemarkTrue(org.geoserver.kml.KMLTransformerTest)
  testRasterPlacemarkFalse(org.geoserver.kml.KMLTransformerTest)
  testSuperOverlayTransformer(org.geoserver.kml.KMLTransformerTest)
  testStyleConverter(org.geoserver.kml.KMLTransformerTest)
  testDynamicSymbolizer(org.geoserver.kml.KMLTransformerTest)
  testTransformer(org.geoserver.kml.KMLTransformerTest)
  test(org.geoserver.kml.KMZMapProducerTest)
  testLatLongInternal(org.geoserver.wms.georss.AtomGeoRSSTransformerTest)
  testSimpleInternal(org.geoserver.wms.georss.AtomGeoRSSTransformerTest)
  testWorldBoundsSuperOverlay(org.geoserver.kml.KMLSuperOverlayTransformerTest)
  testSubtileSuperOverlay(org.geoserver.kml.KMLSuperOverlayTransformerTest)
Tests run: 338, Failures: 0, Errors: 21, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 36 seconds
[INFO] Finished at: Fri Jul 08 11:56:20 UTC 2011
[INFO] Final Memory: 58M/394M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4230/&gt;
