[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4357
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4357/&gt;
Started by user hudson
Updating https://svn.codehaus.org/geoserver/trunk/src
ERROR: Failed to update https://svn.codehaus.org/geoserver/trunk/src
org.tmatesoft.svn.core.SVNCancelException: svn: Operation cancelled
  at hudson.scm.SubversionUpdateEventHandler.checkCancelled(SubversionUpdateEventHandler.java:112)
  at org.tmatesoft.svn.core.wc.SVNBasicClient.checkCancelled(SVNBasicClient.java:460)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.checkCancelled(SVNWCAccess.java:82)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:381)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:397)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:272)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:265)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.openAnchor(SVNWCAccess.java:160)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.update(SVNUpdateClient.java:512)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:401)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:699)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:660)
  at hudson.FilePath.act(FilePath.java:753)
  at hudson.FilePath.act(FilePath.java:735)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:653)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:601)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1038)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:479)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:411)
  at hudson.model.Run.run(Run.java:1257)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:129)
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4358/&gt;
