See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4554/changes>
Changes:
[aaime] Increasing the test permgen, the build won't work on 64bit java anymore otherwise
[aaime] New feature aggregate module
[aaime] Allow a store panel to perform actions before the form is submitted
[aaime] Allow links to show a confirmation popup or other javascript behavior
[aaime] [GEOS-4770] Simplify GetFeatureInfo filters before sending them down to the stores
[aaime] [GEOS-4769] Allow stores to receive the existing catalog as a geotools respository
[...truncated 27714 lines...]
23 Sep 11:12:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3291445791012051897data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock9014338671371468520data>
23 Sep 11:12:19 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.StyleResource.handleObjectDelete(StyleResource.java:218)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:224)
at org.restlet.Finder.handle(Finder.java:300)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:582)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1217)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1236)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1159)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:792)
at org.geoserver.catalog.rest.StyleTest.testDeleteWithLayerReference(StyleTest.java:168)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock8951673460891439132data>
23 Sep 11:12:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock610160897354453053data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock8192718152213089139data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock9108478123033880033data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock6191964338825010950data>
23 Sep 11:12:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock1045436683441168560data>
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.356 sec
Running org.geoserver.catalog.rest.LayerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock880404626411060346data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock5612233622879668029data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock5055932455436842723data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3752110814359539283data>
23 Sep 11:12:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock6111247412315208041data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock9044225400368017299data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock6250647166786429283data>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.898 sec
Results :
Tests run: 191, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT.jar>
Downloading: http://repo.opengeo.org//org/opengeo/geodb/0.6-SNAPSHOT/geodb-0.6-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/restconfig/2.2-SNAPSHOT/restconfig-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/restconfig/2.2-SNAPSHOT/restconfig-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/restconfig/2.2-SNAPSHOT/restconfig-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/restconfig-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/restconfig/2.2-SNAPSHOT/restconfig-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.2-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/web/2.2-SNAPSHOT/web-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/2.2-SNAPSHOT/web-2.2-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core>
[INFO] Copying 5 resources
[INFO] Copying 359 resources
[INFO] [antrun:run {execution: process-resources}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO] Compiling 193 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/src/main/java/org/geoserver/web/data/layer/NewLayerPage.java>:\[39,35\] cannot find symbol
symbol : class StoreListChoiceRenderer
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/src/main/java/org/geoserver/web/data/layer/NewLayerPage.java>:\[40,35\] cannot find symbol
symbol : class StoreListModel
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/src/main/java/org/geoserver/web/data/layer/NewLayerPage.java>:\[196,20\] cannot find symbol
location: class org.geoserver.web.data.layer.NewLayerPage
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/src/main/java/org/geoserver/web/data/layer/NewLayerPage.java>:\[196,42\] cannot find symbol
[INFO] Total time: 7 minutes 13 seconds
[INFO] Finished at: Fri Sep 23 11:12:30 UTC 2011
[INFO] Final Memory: 58M/347M
