[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4755
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4755/&gt;
[...truncated 26791 lines...]
  at org.geoserver.wfs.GetFeature.buildResults(GetFeature.java:672)
  at org.geoserver.wfs.GetFeature.run(GetFeature.java:611)
  at org.geoserver.wfs.DefaultWebFeatureService20.getFeature(DefaultWebFeatureService20.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService20.getFeatureWithLock(DefaultWebFeatureService20.java:102)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy15.getFeatureWithLock(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:763)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:560)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1217)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1236)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1159)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:778)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:725)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:705)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:912)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:895)
  at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:126)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
  at sun.reflect.GeneratedMethodAccessor217.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: java.lang.RuntimeException: Encode failed for version. Cause: Empty version union
  at org.geotools.xml.impl.AttributeEncodeExecutor.visit(AttributeEncodeExecutor.java:93)
  at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:220)
  at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:186)
  at org.geotools.xml.impl.BindingVisitorDispatch.walk(BindingVisitorDispatch.java:47)
  at org.geotools.xml.impl.ElementEncoder.encode(ElementEncoder.java:93)
  at org.geotools.xml.Encoder.encode(Encoder.java:1142)
  at org.geotools.xml.Encoder.encode(Encoder.java:1131)
  at org.geotools.xml.Encoder.encode(Encoder.java:887)
  at org.geotools.xml.Encoder.encode(Encoder.java:584)
  at org.geotools.xml.Encoder.encodeAsString(Encoder.java:1116)
  at org.geoserver.wfs.GetFeature.encodeQueryAsKvp(GetFeature.java:819)
  ... 68 more
Caused by: java.lang.IllegalArgumentException: Empty version union
  at org.geotools.filter.v2_0.bindings.VersionTypeBinding.encode(VersionTypeBinding.java:69)
  at org.geotools.xml.impl.AttributeEncodeExecutor.visit(AttributeEncodeExecutor.java:89)
  ... 78 more
09 Nov 16:38:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock972436847702539049data&gt;
09 Nov 16:38:17 ERROR [geoserver.ows] -
java.lang.RuntimeException: Unable to encode filter [ Locks.0, Locks.1 ]
  at org.geoserver.wfs.GetFeature.encodeQueryAsKvp(GetFeature.java:822)
  at org.geoserver.wfs.GetFeature.buildKvpFromRequest(GetFeature.java:744)
  at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testGetFeatureWithLockReleaseActionSome(GetFeatureWithLockTest.java:180)
  ... 68 more
  ... 78 more
09 Nov 16:38:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock5009612954892660861data&gt;
Tests run: 6, Failures: 5, Errors: 0, Skipped: 0, Time elapsed: 1.451 sec <<< FAILURE!
Running org.geoserver.wfs.ReprojectionWriteTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2266076395417488813data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6100539853651089650data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6545733019712859500data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.737 sec
Running org.geoserver.wfs.AliasTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3679421164102641867data&gt;
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:cdf="http://www.opengis.net/cite/data&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gs="http://geoserver.org" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/data&quot;&gt;
  <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd&quot;/&gt;
  <xsd:complexType name="ft15Type">
    <xsd:complexContent>
      <xsd:extension base="gml:AbstractFeatureType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="boundedBy" nillable="true" type="gml:PolygonPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
        </xsd:sequence>
      </xsd:extension>
    </xsd:complexContent>
  </xsd:complexType>
  <xsd:element name="ft15" substitutionGroup="gml:_Feature" type="cdf:ft15Type"/>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.137 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
09 Nov 16:38:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2269869110264357185data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.388 sec
Results :
Failed tests:
  testWithFilter(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
  testNextPreviousLinksPOST(org.geoserver.wfs.v2_0.GetFeaturePagingTest)
  testWorkspaceQualified(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
  testLayerQualified(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
  testUpdateLockedFeatureWithLockId(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
  testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
  testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.v2_0.GetFeatureWithLockTest)
Tests run: 401, Failures: 7, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 58 seconds
[INFO] Finished at: Wed Nov 09 16:38:18 UTC 2011
[INFO] Final Memory: 55M/392M
sorry for the breakage, failure given to some ResourceId changes in
geotools, working on it....
Gabriel
okay, waiting for the build server to build geotools which should fix
the geoserver build.
cross fingers,
Gabriel
On Wed, Nov 9, 2011 at 3:45 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4756/&gt;
