[Geoserver-devel] Build failed in Hudson: geoserver-trunk #518
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/518/changes
Changes:
[arneke] GWC extension, including xstream jar in zip
[...truncated 7932 lines...]
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:935)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:902)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:566)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:541)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:700)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:683)
  at org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse(HistoryRelatedTest.java:296)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:124)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 10, Failures: 9, Errors: 0, Skipped: 0, Time elapsed: 12.595 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
16 Sep 19:42:49 ERROR [data.postgis] - Could not version enable: archsites
java.io.IOException: This feature type (archsites) is associated to an unsupported fid mapper: class org.geotools.data.jdbc.fidmapper.NullFIDMapper
The supported fid mapper classes are: [class org.geotools.data.jdbc.fidmapper.BasicFIDMapper, class org.geotools.data.jdbc.fidmapper.MultiColumnFIDMapper, class org.geotools.data.postgis.fidmapper.PostGISAutoIncrementFIDMapper]
  at org.geotools.data.postgis.VersionedPostgisDataStore.enableVersioning(VersionedPostgisDataStore.java:1049)
  at org.geotools.data.postgis.VersionedPostgisDataStore.setVersioned(VersionedPostgisDataStore.java:387)
  at org.geotools.data.postgis.VersionedPostgisDataStoreFactory.createDataStore(VersionedPostgisDataStoreFactory.java:155)
  at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:75)
  at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:155)
  at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:29)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importDataStores(LegacyCatalogImporter.java:311)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importCatalog(LegacyCatalogImporter.java:256)
  at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:136)
  at org.geoserver.config.LegacyGeoServerLoader.loadCatalog(LegacyGeoServerLoader.java:35)
  at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:89)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:164)
  at org.geoserver.wfsv.WFSVTestSupport.oneTimeSetUp(WFSVTestSupport.java:35)
  at org.geoserver.wfsv.LogOrderTest.oneTimeSetUp(LogOrderTest.java:21)
  at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
16 Sep 19:42:51 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp\}archsites is read-only
  at org.geoserver.wfs.Transaction.execute(Transaction.java:272)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfsv.DefaultVersioningWebFeatureService.transaction(DefaultVersioningWebFeatureService.java:164)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy10.transaction(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:517)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:194)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.geoserver.wfsv.LogOrderTest.oneTimeSetUp(LogOrderTest.java:43)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.194 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.909 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
[Fatal Error] :-1:-1: Premature end of file.
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.037 sec <<< FAILURE!
Results :
Failed tests:
  testGetFeatureBeforeAfter(org.geoserver.wfsv.HistoryRelatedTest)
  testVersionedFeatureCollection10(org.geoserver.wfsv.HistoryRelatedTest)
  testVersionedFeatureCollection11(org.geoserver.wfsv.HistoryRelatedTest)
  testLog10(org.geoserver.wfsv.HistoryRelatedTest)
  testLog11(org.geoserver.wfsv.HistoryRelatedTest)
  testLog10Html(org.geoserver.wfsv.HistoryRelatedTest)
  testGetDiff11(org.geoserver.wfsv.HistoryRelatedTest)
  testGetDiff10(org.geoserver.wfsv.HistoryRelatedTest)
  testGetDiff11Reverse(org.geoserver.wfsv.HistoryRelatedTest)
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 14, Failures: 10, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 6 minutes 22 seconds
[INFO] Finished at: Tue Sep 16 19:42:52 EDT 2008
[INFO] Final Memory: 34M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/519/changes
Changes:
[jdeolive] GEOS-2206, including contact / provider info in wfs 1.1 caps document
[jdeolive] GEOS-2208, renaming / backing up feature type directories rather than deleting them
[jdeolive] GEOS-2203, including disabled feature types in master list
[...truncated 2155 lines...]
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.9">
<gml:boundedBy>
<gml:Envelope srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:lowerCorner>500000.0 500000.0</gml:lowerCorner>
<gml:upperCorner>500100.0 500100.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Running org.geoserver.wfs.DescribeFeatureTest
16 Sep 20:40:54 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:131)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at $Proxy10.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:38)
  at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.253 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.305 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.167 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.461 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.362 sec <<< FAILURE!
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.363 sec
Results :
Failed tests:
  test(org.geoserver.wfs.v1_1.CapabilitiesTransformerTest)
Tests run: 138, Failures: 1, Errors: 0, Skipped: 0
Sep 16, 2008 8:40:56 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 31 seconds
[INFO] Finished at: Tue Sep 16 20:40:57 EDT 2008
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/520/changes
Changes:
[jdeolive] GEOS-2221, caching reflective information about a class
[jdeolive] GEOS-2206, ensuring caps doc validates against ows schmea
[...truncated 117 lines...]
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Sep 16, 2008 9:37:01 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 19 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 7 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.532 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Sep 16, 2008 9:37:21 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.95 sec
Results :
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/2.0-SNAPSHOT/data-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/2.0-SNAPSHOT/data-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/2.0-SNAPSHOT/data-2.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:ogc:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:unsupported:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 71 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/java/org/geoserver/ows/util/OwsUtils.java :[52,22] cannot find symbol
symbol : class ClassProperties
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/java/org/geoserver/ows/util/OwsUtils.java :[57,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/java/org/geoserver/ows/util/OwsUtils.java :[52,90] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/java/org/geoserver/ows/util/OwsUtils.java :[59,8] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/java/org/geoserver/ows/util/OwsUtils.java :[61,29] cannot find symbol
[INFO] Total time: 1 minute 8 seconds
[INFO] Finished at: Tue Sep 16 21:37:32 EDT 2008
[INFO] Final Memory: 26M/48M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/521/changes
