[Geoserver-devel] Build failed in Hudson: geoserver-trunk #530
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/530/changes
Changes:
[groldan] new faster wms getmapresponse tests aiming at reaching 100% coverage
[...truncated 2698 lines...]
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 323
Oct 3, 2008 6:39:10 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 289
Oct 3, 2008 6:39:11 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 289
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.372 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<h4>testType</h4>
<ul class="textattributes">
  <li><strong><span class="atr-name">string</span>:</strong> <span class="atr-value">three</span></li>
  <li><strong><span class="atr-name">int</span>:</strong> <span class="atr-value">3</span></li>
  <li><strong><span class="atr-name">double</span>:</strong> <span class="atr-value">3.3</span></li>
</ul>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.548 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.254 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLReflectorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
<kml>
  <Document xmlns:atom="http://purl.org/atom/ns#&quot;&gt;
    <name>Points</name>
    <Style id="GeoServerStylePoints.0">
      <IconStyle>
        <colorMode>normal</colorMode>
        <Icon>
          <href>http://localhost:80/geoserver/styles/bridge.png&lt;/href&gt;
        </Icon>
      </IconStyle>
      <LabelStyle>
        <color>00ffffff</color>
      </LabelStyle>
    </Style>
    <Placemark id="Points.0">
      <name><![CDATA[Points.0]]></name>
      <description><![CDATA[<h4>Points</h4>
  <li><strong><span class="atr-name">id</span>:</strong> <span class="atr-value">t0000</span></li>
</ul>
]]></description>
      <LookAt>
        <longitude>500050.0</longitude>
        <latitude>500050.0</latitude>
        <heading>10.0</heading>
        <tilt>10.0</tilt>
        <range>700</range>
      </LookAt>
      <styleUrl>#GeoServerStylePoints.0</styleUrl>
      <Point>
        <coordinates>500050.0,500050.0</coordinates>
      </Point>
    </Placemark>
  </Document>
</kml>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.335 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.193 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.wms.CapabilitiesTest
Oct 3, 2008 6:39:15 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.354 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Oct 3, 2008 6:39:15 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.181 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.216 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.225 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.195 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
03 Oct 06:39:17 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
  at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:104)
  at org.geoserver.ows.adapters.KvpRequestReaderAdapter.createRequest(KvpRequestReaderAdapter.java:94)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:987)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:387)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:195)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:935)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:902)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:439)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:420)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:46)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:124)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor109.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
03 Oct 06:39:19 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:125)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:572)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:641)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:202)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:633)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:122)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:181)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:141)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:407)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:177)
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.598 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.183 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Results :
Failed tests:
  testExecuteTilingRequested(org.vfny.geoserver.wms.responses.GetMapResponseTest)
Tests run: 118, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 50 seconds
[INFO] Finished at: Fri Oct 03 06:39:21 EDT 2008
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/531/changes
Changes:
[jdeolive] GEOS-2262, setting charset output
[...truncated 5659 lines...]
Oct 4, 2008 9:44:24 AM org.geoserver.wms.WMSTestSupport assertNotBlank
<h4>testType</h4>
</ul>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.627 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.299 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
<kml>
    <name>Points</name>
      <IconStyle>
        <Icon>
        </Icon>
      </IconStyle>
      <LabelStyle>
      </LabelStyle>
    </Style>
</ul>
]]></description>
      <LookAt>
        <tilt>10.0</tilt>
        <range>700</range>
      </LookAt>
      <Point>
      </Point>
    </Placemark>
  </Document>
</kml>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.391 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.219 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Oct 4, 2008 9:44:28 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.327 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Oct 4, 2008 9:44:29 AM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.319 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.189 sec
04 Oct 09:44:31 ERROR [geoserver.ows] -
</ServiceException>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
04 Oct 09:44:33 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.482 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Results :
Failed tests:
[INFO] Total time: 8 minutes 1 second
[INFO] Finished at: Sat Oct 04 09:44:35 EDT 2008
[INFO] Final Memory: 33M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/532/changes
