See http://hudson.opengeo.org/hudson/job/geoserver-trunk/558/changes
Changes:
[bmmpxf] Rewrote instructions for better clarity and accuracy (see GEOS-2321).
[bmmpxf] Updated RUNNING.txt so it will hopefully be more useful. (See GEOS-2271)
[...truncated 3178 lines...]
Nov 5, 2008 9:40:33 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogForward since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogBackwards since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.wfsv.LogOrderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.wfsv.RollbackTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testInvalidRollback since test data is not available
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.1-SNAPSHOT/wfsv-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.1-SNAPSHOT/wfsv-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.1-SNAPSHOT/wfsv-1.7.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Release Module
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-dependency-plugin/2.0/maven-dependency-plugin-2.0.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-dependency-plugin/2.0/maven-dependency-plugin-2.0.pom
2/11K
6/11K
6/11K
8/11K
9/11K
11/11K
11K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-dependency-plugin/2.0/maven-dependency-plugin-2.0.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-dependency-plugin/2.0/maven-dependency-plugin-2.0.jar
4/87K
4/87K
8/87K
12/87K
12/87K
16/87K
20/87K
24/87K
26/87K
30/87K
34/87K
38/87K
42/87K
46/87K
50/87K
52/87K
54/87K
58/87K
59/87K
63/87K
67/87K
71/87K
75/87K
79/87K
83/87K
87/87K
87/87K
87K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-antrun-plugin/1.1/maven-antrun-plugin-1.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-antrun-plugin/1.1/maven-antrun-plugin-1.1.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-plugin-parent/2.0.1/maven-plugin-parent-2.0.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-plugin-parent/2.0.1/maven-plugin-parent-2.0.1.pom
4/7K
7/7K
7K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-antrun-plugin/1.1/maven-antrun-plugin-1.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-antrun-plugin/1.1/maven-antrun-plugin-1.1.jar
4/11K
4/11K
5/11K
9/11K
9/11K
11/11K
11K downloaded
[INFO] [clean:clean]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://maven.geotools.fr/repository//org.slf4j/poms/slf4j-simple-1.0.1.pom
Downloading: http://lists.refractions.net/m2//org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.pom
Downloading: http://www.mortbay.org/maven2/release/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.pom
Downloading: http://maven.restlet.org/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.pom
Downloading: http://repo1.maven.org/maven2/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.pom
392/392b
392b downloaded
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd3c4e3a03c39fae121c8b16c4ed8185619f330cf'; remote = '2b435d8390b3a997377e2c23edd856dc2f73b96c' - RETRYING
392/392b
392b downloaded
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'd3c4e3a03c39fae121c8b16c4ed8185619f330cf'; remote = '2b435d8390b3a997377e2c23edd856dc2f73b96c' - IGNORING
[INFO] snapshot org.geotools:gt-gml:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-db2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-mysql:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-oracle-spatial:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-vpf:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-imagepyramid:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalmrsid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdal:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalframework:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalecw:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdaldted:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalkakadujp2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalmrsidjp2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalecwjp2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalerdasimg:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-gdalnitf:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-imagereadmt:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geoserver:wfsv:2.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.6-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//org.geoserver/poms/gwc-0.1.pom
Downloading: http://lists.refractions.net/m2//org/geoserver/gwc/0.1/gwc-0.1.pom
Downloading: http://www.mortbay.org/maven2/release/org/geoserver/gwc/0.1/gwc-0.1.pom
Downloading: http://maven.restlet.org/org/geoserver/gwc/0.1/gwc-0.1.pom
Downloading: http://repo1.maven.org/maven2/org/geoserver/gwc/0.1/gwc-0.1.pom
[INFO] snapshot org.geoserver.extension:h2:1.7.0-SNAPSHOT: checking for updates from refractions
Downloading: http://lists.refractions.net/m2//org/geoserver/extension/h2/1.7.0-SNAPSHOT/h2-1.7.0-SNAPSHOT.pom
Downloading: http://maven.geotools.fr/repository//commons-logging/jars/commons-logging-1.0.jar
Downloading: http://lists.refractions.net/m2//commons-logging/commons-logging/1.0/commons-logging-1.0.jar
Downloading: http://www.mortbay.org/maven2/release/commons-logging/commons-logging/1.0/commons-logging-1.0.jar
Downloading: http://maven.restlet.org/commons-logging/commons-logging/1.0/commons-logging-1.0.jar
Downloading: http://repo1.maven.org/maven2/commons-logging/commons-logging/1.0/commons-logging-1.0.jar
4/21K
4/21K
8/21K
12/21K
12/21K
15/21K
19/21K
21/21K
21K downloaded
Downloading: http://maven.geotools.fr/repository//org.slf4j/jars/slf4j-simple-1.0.1.jar
Downloading: http://lists.refractions.net/m2//org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.jar
Downloading: http://www.mortbay.org/maven2/release/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.jar
Downloading: http://maven.restlet.org/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.jar
Downloading: http://repo1.maven.org/maven2/org/slf4j/slf4j-simple/1.0.1/slf4j-simple-1.0.1.jar
4/13K
6/13K
10/13K
13/13K
13K downloaded
[INFO] snapshot org.geoserver:wfs:2.0-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//org.geoserver/jars/gwc-0.1.jar
Downloading: http://lists.refractions.net/m2//org/geoserver/gwc/0.1/gwc-0.1.jar
Downloading: http://www.mortbay.org/maven2/release/org/geoserver/gwc/0.1/gwc-0.1.jar
Downloading: http://maven.restlet.org/org/geoserver/gwc/0.1/gwc-0.1.jar
Downloading: http://repo1.maven.org/maven2/org/geoserver/gwc/0.1/gwc-0.1.jar
Downloading: http://lists.refractions.net/m2//org/geoserver/extension/h2/1.7.0-SNAPSHOT/h2-1.7.0-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver:gwc:jar:0.1
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver -DartifactId=gwc -Dversion=0.1 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=gwc -Dversion=0.1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver:release:jar:2.0-SNAPSHOT
2) org.geoserver:gwc:jar:0.1
2) org.geoserver.extension:h2:jar:1.7.0-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver.extension -DartifactId=h2 -Dversion=1.7.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
mvn deploy:deploy-file -DgroupId=org.geoserver.extension -DartifactId=h2 -Dversion=1.7.0-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
refractions (http://lists.refractions.net/m2/),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
[INFO] Total time: 4 minutes 17 seconds
[INFO] Finished at: Wed Nov 05 21:41:11 EST 2008
[INFO] Final Memory: 45M/63M
Failed to send e-mail to bmmpxf because no e-mail address is known, and no default e-mail domain is configured
