[Geoserver-devel] Build failed in Hudson: geoserver-trunk #57
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/57/changes
Changes:
[dgricci] Updates of French resources
[...truncated 2441 lines...]
Apr 6, 2008 5:41:27 AM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.getoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.getoserver.wfsv.HistoryRelatedTest
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetFeatureBeforeAfter since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testLog since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testLogHtml since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiff since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiffHtml since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiffReverse since test data is not available
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] [compiler:compile]
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 20 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.485 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.168 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.616 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.092 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.324 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.704 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.332 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.54 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.136 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.56 sec
Results :
Tests run: 54, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] artifact org.geoserver.maven:config: checking for updates from mortbay-repo
[INFO] artifact org.geoserver.maven:config: checking for updates from refractions-plugins
[INFO] artifact org.geoserver.maven:config: checking for updates from central
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Compiling 109 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] Compiling 4 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.816 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.292 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
     [copy] Copying 14 files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1204 msecs]
[INFO] Building war: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building Test Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target
[INFO] No sources to compile
[INFO] Compiling 12 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest
Apr 6, 2008 5:42:20 AM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
INFO: testing single rule dirt_road from style Default Styler
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.52 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.kml.KMLWriterTest
Running org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.032 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.SVGMapProducerTest
Apr 6, 2008 5:42:20 AM org.geotools.map.DefaultMapContext setAreaOfInterest
INFO: USing a deprecated method!
Apr 6, 2008 5:42:20 AM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 72 ms
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.vfny.geoserver.wms.responses.GetMapResponseTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.vfny.geoserver.wms.responses.map.GIFMapProducerTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.012 sec <<< FAILURE!
Results :
Tests in error:
  testUserSpecifiedRule(org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest)
  testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testDefaultStyle(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testBlueLake(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
  testDefaultStyle(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
  testBlueLake(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
Tests run: 14, Failures: 0, Errors: 7, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports for the individual test results.
[INFO] Total time: 5 minutes 42 seconds
[INFO] Finished at: Sun Apr 06 05:42:20 EDT 2008
[INFO] Final Memory: 36M/63M
Failed to send e-mail to dgricci because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/58/changes
Changes:
[jdeolive] added a paging feature source wrapper
[dwinslow] Re-enable the refractions repository.
[...truncated 433 lines...]
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from opengeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt2-cql:2.5-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Error transferring file
[INFO] Repository 'opengeo' will be blacklisted
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 119 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.644 sec
Running org.geoserver.feature.PagingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.448 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from opengeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Error transferring file
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] Compiling 35 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model v1.1.0
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target
[INFO] Compiling 149 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Model v1.1.1
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target
[INFO] Compiling 94 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot; does not exist. Creating the directory.
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot; does not exist. Will create one.
Annotated grammar generated successfully in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Compiling 54 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/classes
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/DefaultWebCoverageService111.java :[245,59] cannot find symbol
symbol : constructor GridGeometry2D(org.opengis.referencing.operation.MathTransform,org.geotools.geometry.GeneralEnvelope)
location: class org.geotools.coverage.grid.GridGeometry2D
[INFO] Total time: 3 minutes 23 seconds
[INFO] Finished at: Mon Apr 07 12:40:00 EDT 2008
[INFO] Final Memory: 33M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/59/changes
Changes:
[jdeolive] temporary hookup of paging
[...truncated 434 lines...]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.408 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.7 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 5 minutes 19 seconds
[INFO] Finished at: Mon Apr 07 13:41:50 EDT 2008
[INFO] Final Memory: 35M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/60/changes
[...truncated 455 lines...]
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.404 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.549 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 12 minutes 8 seconds
[INFO] Finished at: Mon Apr 07 13:54:03 EDT 2008
[INFO] Final Memory: 32M/63M
Seems a recent change to GridGeometry2D on geotools trunk is causing this failure. I looked briefly and the changes do not seem trivial... although i have zero knowledge of coverage stuff.
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 119 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes [INFO] [resources:testResources]
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes [INFO] [surefire:test]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 35 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes [INFO] [resources:testResources]
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 149 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/classes [INFO] [resources:testResources]
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 94 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/classes [INFO] [resources:testResources]
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target [INFO] [cobertura:clean {execution: default}]
Annotated grammar generated successfully in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj [INFO] [javacc:javacc {execution: javacc}]
[INFO] Compiling 54 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/classes [INFO] ------------------------------------------------------------------------
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Register now and save $200. Hurry, offer ends at 11:59 p.m., Monday, April 7! Use priority code J8TLD2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-devel mailing list
!DSPAM:4007,47fa5ff238795219720167!
Justin Deoliveira
The Open Planning Project
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/61/changes
Changes:
[bmmpxf] Updated README for 1.6.3
[...truncated 430 lines...]
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.44 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.46 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 3 minutes 13 seconds
[INFO] Finished at: Mon Apr 07 16:39:49 EDT 2008
[INFO] Final Memory: 34M/63M
Failed to send e-mail to bmmpxf because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/62/changes
Changes:
[dwinslow] Use the paging stuff for KML output.
[...truncated 468 lines...]
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from opengeo
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.504 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.48 sec
Results :
[INFO] [jar:jar]
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 2 minutes 35 seconds
[INFO] Finished at: Mon Apr 07 17:39:11 EDT 2008
[INFO] Final Memory: 30M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/63/changes
Changes:
[arneke] Configuration for connection to geoserver
[...truncated 462 lines...]
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.568 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.504 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 4 minutes 13 seconds
[INFO] Finished at: Mon Apr 07 18:40:49 EDT 2008
[INFO] Final Memory: 33M/62M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/64/changes
[...truncated 469 lines...]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.916 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.476 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] Total time: 1 minute 12 seconds
[INFO] Finished at: Tue Apr 08 14:26:14 EDT 2008
[INFO] Final Memory: 34M/61M
I was not aware that GeoServer was already using this new method introduced only one or two weeks ago...
To fix the compilation failure, replace:
    new GridGeometry2D(gridToCRS, envelope)
by
    new GridGeometry2D(PixelInCell.CENTER, gridToCRS, envelope, null)
  Martin
Appologize, just realized it has been introduced a few months ago. But still new in GeoTools 2.5, so subject to change (while I do not envision other changes for now)...
  Martin
Cool, thanks for the fix martin, I just committed it. Hopefully the build is back soon.
  Martin
!DSPAM:4007,47fbc1ba11102092453641!
Justin Deoliveira
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/65/changes
