[Geoserver-devel] Build failed in Hudson: geoserver-trunk #6
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/6/changes
Changes:
[arneke] GEOS-1801 Support for multiple featuretypes in featureCollections
[arneke] GEOS-1803 Update geoserver link to geoserver.org
[arneke] Cosmetic cleanup of WMS Reflector code, correct indentation
[arneke] GEOS-1797 WMS Reflector does not deal with coverages
[dwinslow] Documentation tweaks, code cleanup in rest package
[dwinslow] Removing conditional dependency on RESTConfig since the rest support package moved to main.
[arneke] GEOS-1806 Image Pyramid extension was not included due to missing dependency
[dwinslow] Remove some debugging messages from GZIP compression filter so they won't gunk up the log files
[...truncated 1041 lines...]
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:735)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:330)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:311)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:478)
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:78)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:102)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
17 Mar 13:52:10 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:146)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 42 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:125)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
  ... 44 more
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:436)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:528)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:158)
  ... 42 more
  ... 44 more
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:165)
  ... 42 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:172)
  ... 44 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.864 sec
Results :
Tests in error:
  testAntimeridianWorld(org.geoserver.wcs.GetCoverageTest)
  testAntimeridianTaz(org.geoserver.wcs.GetCoverageTest)
  testDefaultGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testGridOffsetsSubsample(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyInterpolation(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyField(org.geoserver.wcs.GetCoverageTest)
  testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
Tests run: 76, Failures: 0, Errors: 11, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 18 seconds
[INFO] Finished at: Mon Mar 17 13:52:11 EDT 2008
[INFO] Final Memory: 30M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/7/changes
Changes:
[dwinslow] Port filtering code to work on a list of SyndEntry's instead of TransactionEvents.
[dwinslow] Serialize to disk and use that for final output
[arneke] GEOS-1801 code cleanup (+old sins)
[...truncated 1143 lines...]
  ... 42 more
  ... 44 more
18 Mar 04:43:17 ERROR [geoserver.ows] -
java.io.IOException
  ... 42 more
  ... 44 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.604 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree are up to date.
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.0-SNAPSHOT/wcs1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.0-SNAPSHOT/wcs1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.0-SNAPSHOT/wcs1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Validation Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 6 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target
[INFO] Compiling 80 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] Compiling 158 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[19,28] cannot find symbol
symbol : class AttributeType
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[20,28] cannot find symbol
symbol : class Feature
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[23,28] cannot find symbol
symbol : class FeatureType
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[62,34] cannot find symbol
symbol : method getTypeName()
location: interface org.opengis.feature.type.FeatureType
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[105,20] cannot find symbol
location: class org.geoserver.wfs.response.GeoJSONOutputFormat
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[106,20] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[109,24] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONOutputFormat.java :[117,24] cannot find symbol
[INFO] Total time: 1 minute 25 seconds
[INFO] Finished at: Tue Mar 18 04:43:24 EDT 2008
[INFO] Final Memory: 31M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/8/changes
