[Geoserver-devel] Build failed in Hudson: geoserver-trunk #610
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/610/changes
Changes:
[groldan] fixed wfsv parent version and dependency over wfs instead of wfs11 which does not exist on trunk
[...truncated 3332 lines...]
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-postgis:2.6-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.593 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.402 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1587 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from refractions
[INFO] Nothing to compile - all classes are up to date
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-0.1-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1-sources.jar
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.644 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.6-SNAPSHOT: checking for updates from refractions
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/DefaultVersioningWebFeatureService.java :[112,15] cannot find symbol
symbol : constructor GetCapabilities(org.geoserver.wfs.WFS,org.vfny.geoserver.global.Data,java.util.List<org.geotools.util.Version>)
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/kvp/GetVersionedFeatureRequestReader.java :[16,8] cannot find symbol
symbol : constructor GetFeatureKvpRequestReader(java.lang.Class<net.opengis.wfsv.GetVersionedFeatureType>,org.vfny.geoserver.global.Data,org.opengis.filter.FilterFactory,org.geoserver.wfs.WebFeatureService)
location: class org.geoserver.wfs.kvp.GetFeatureKvpRequestReader
[INFO] Total time: 3 minutes 32 seconds
[INFO] Finished at: Thu Nov 27 20:40:12 EST 2008
[INFO] Final Memory: 40M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/611/changes
