See http://hudson.opengeo.org/hudson/job/geoserver-trunk/636/changes
Changes:
[aaime] Fixing the unit test, it wasn't really testing loading overrides from the data dir
[aaime] GEOS-1783 override an existing EPSG definition in the property file
[...truncated 588 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:986)
... 31 more
10 Dec 22:37:30 ERROR [geoserver.global] - Could not load feature type cite:BasicPolygons
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:990)
at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:515)
at org.vfny.geoserver.global.Data.toDTO(Data.java:1599)
at org.vfny.geoserver.global.Config.getData(Config.java:107)
at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:47)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:129)
... 31 more
10 Dec 22:37:30 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Dec 10 22:37:29 EST 2008]; root of context hierarchy
10 Dec 22:37:30 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
10 Dec 22:37:30 INFO [geoserver.global] - Done disposing datastores.
Dec 10, 2008 10:37:30 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.187 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
10 Dec 22:37:30 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Dec 22:37:30 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Dec 22:37:30 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.config.util.XStreamPersisterTest
10 Dec 22:37:30 INFO [org.geoserver] - Persisting store 'bar'
10 Dec 22:37:30 INFO [org.geoserver] - Loaded store 'bar', disabled
10 Dec 22:37:30 INFO [org.geoserver] - Persisting workspace '{foo=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com, null=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com}'
10 Dec 22:37:30 INFO [org.geoserver] - Persisting namespace '{null=acme, acme=acme}'
10 Dec 22:37:30 INFO [org.geoserver] - Persisting store 'foo'
10 Dec 22:37:30 INFO [org.geoserver] - Loading workspace 'foo'
10 Dec 22:37:30 INFO [org.geoserver] - Loading namespace 'acme'
10 Dec 22:37:30 INFO [org.geoserver] - Loaded store 'foo', disabled
10 Dec 22:37:30 INFO [org.geoserver] - Persisting resource 'ft'
10 Dec 22:37:30 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Dec 10, 2008 10:37:30 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.061 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Dec 10, 2008 10:37:30 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cgf'
Dec 10, 2008 10:37:31 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.596 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 40, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Dec 10, 2008 10:37:31 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.072 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Failed tests:
testOvveride(org.vfny.geoserver.crs.OvverideCRSTest)
Tests run: 107, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 53 seconds
[INFO] Finished at: Wed Dec 10 22:37:31 EST 2008
[INFO] Final Memory: 29M/63M
