[Geoserver-devel] Build failed in Hudson: geoserver-trunk #640
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/640/changes
Changes:
[jdeolive] GEOS-2509, upgraded h2 version
[jdeolive] cleaned up extension dependencies, added arcsde extension
started
Updating https://svn.codehaus.org/geoserver/trunk/src
U pom.xml
A extension/arcsde
AU extension/arcsde/pom.xml
U extension/oracle/pom.xml
U extension/pom.xml
U web/pom.xml
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal
At revision 10907
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
At revision 10907
At revision 10907
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
[geoserver] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: unknown
POM Location: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml
Reason: Parse error reading POM. Reason: Unrecognised tag: 'profile' (position: START_TAG seen ...</modules>\n <profile>... @32:14) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Parse error reading POM. Reason: Unrecognised tag: 'profile' (position: START_TAG seen ...</modules>\n <profile>... @32:14) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:378)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:292)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Parse error reading POM. Reason: Unrecognised tag: 'profile' (position: START_TAG seen ...</modules>\n <profile>... @32:14) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1592)
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1553)
  at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:504)
  at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:198)
  at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:583)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:461)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:534)
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
  ... 11 more
Caused by: org.codehaus.plexus.util.xml.pull.XmlPullParserException: Unrecognised tag: 'profile' (position: START_TAG seen ...</modules>\n <profile>... @32:14)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseProfile(MavenXpp3Reader.java:3424)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseModel(MavenXpp3Reader.java:2239)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.read(MavenXpp3Reader.java:4422)
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1588)
  ... 18 more
[INFO] Total time: 2 seconds
[INFO] Finished at: Fri Dec 12 00:36:41 EST 2008
[INFO] Final Memory: 4M/8M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/641/changes
Changes:
[jdeolive] disabling arcsde extension
[jdeolive] fixing typo
[...truncated 3512 lines...]
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] snapshot org.geotools:gt-postgis:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.659 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.377 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1485 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.534 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.6-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//com.oracle/jars/ojdbc14-10.2.0.3.0.jar
Downloading: http://lists.refractions.net/m2//com/oracle/ojdbc14/10.2.0.3.0/ojdbc14-10.2.0.3.0.jar
Downloading: http://www.mortbay.org/maven2/release/com/oracle/ojdbc14/10.2.0.3.0/ojdbc14-10.2.0.3.0.jar
Downloading: http://maven.restlet.org/com/oracle/ojdbc14/10.2.0.3.0/ojdbc14-10.2.0.3.0.jar
Downloading: http://repo1.maven.org/maven2/com/oracle/ojdbc14/10.2.0.3.0/ojdbc14-10.2.0.3.0.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) com.oracle:ojdbc14:jar:10.2.0.3.0
  Try downloading the file manually from:
      http://www.oracle.com/technology/software/tech/java/sqlj_jdbc/index.html
  Then, install it using the command:
      mvn install:install-file -DgroupId=com.oracle -DartifactId=ojdbc14 -Dversion=10.2.0.3.0 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=com.oracle -DartifactId=ojdbc14 -Dversion=10.2.0.3.0 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.extension:oracle:jar:2.0-SNAPSHOT
    2) com.oracle:ojdbc14:jar:10.2.0.3.0
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  geotools (http://maven.geotools.fr/repository/),
  mortbay (http://www.mortbay.org/maven2/release)
[INFO] Total time: 3 minutes 16 seconds
[INFO] Finished at: Fri Dec 12 01:39:49 EST 2008
[INFO] Final Memory: 37M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/642/changes
