[Geoserver-devel] Build failed in Hudson: geoserver-trunk #643
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/643/changes
started
Updating https://svn.codehaus.org/geoserver/trunk/src
ERROR: Failed to update https://svn.codehaus.org/geoserver/trunk/src
org.tmatesoft.svn.core.SVNException: svn: This client is too old to work with working copy 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension’; please get a newer Subversion client
  at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNAdminAreaFactory.open(SVNAdminAreaFactory.java:132)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:344)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:372)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:261)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.openAnchor(SVNWCAccess.java:153)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:145)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:381)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:353)
  at hudson.FilePath.act(FilePath.java:301)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:347)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:300)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
  at hudson.model.Run.run(Run.java:659)
  at hudson.model.Build.run(Build.java:101)
  at hudson.model.ResourceController.execute(ResourceController.java:70)
  at hudson.model.Executor.run(Executor.java:65)
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/644/changes
started
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/645/changes
started
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/646/changes
