[Geoserver-devel] Build failed in Hudson: geoserver-trunk #656
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/656/changes
Changes:
[aaime] Make WFS PPIO compile in face of wfs configuration changes... just a stop gap measure, as we'd need to distinguish wfs 1.0 and wfs 1.1
[...truncated 2790 lines...]
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<gml:boundedBy>
<gml:Envelope srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:lowerCorner>500000.0 500000.0</gml:lowerCorner>
<gml:upperCorner>500100.0 500100.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.162 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.wfs.DescribeFeatureTest
22 Dec 19:39:33 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:134)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:96)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy10.describeFeatureType(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:573)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:984)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:951)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:574)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:549)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:726)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:709)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:45)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:129)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor155.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.251 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.296 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.181 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.341 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.771 sec
Running org.geoserver.wfs.response.ShapeZipTest
Dec 22, 2008 7:39:34 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.774 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.365 sec
Results :
Tests run: 142, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0-SNAPSHOT/wfs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0-SNAPSHOT/wfs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0-SNAPSHOT/wfs-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-render:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wfs:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wms:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-xml:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.6-SNAPSHOT: checking for updates from refractions
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  it.geosolutions.imageio-ext:imageio-ext-arcgrid:jar:1.0-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  refractions (http://lists.refractions.net/m2/),
  maven2-repository.dev.java.net (http://download.java.net/maven/2),
  geotools (http://maven.geotools.fr/repository/),
  mortbay (http://www.mortbay.org/maven2/release)
Path to dependency:
  1) org.geoserver:wms:jar:2.0-SNAPSHOT
  2) org.geoserver:wcs:jar:2.0-SNAPSHOT
  3) org.geotools:gt-arcgrid:jar:2.6-SNAPSHOT
  4) it.geosolutions.imageio-ext:imageio-ext-arcgrid:jar:1.0-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/it/geosolutions/imageio-ext/imageio-ext-arcgrid/1.0-SNAPSHOT/imageio-ext-arcgrid-1.0-SNAPSHOT.jar
[INFO] Total time: 3 minutes 1 second
[INFO] Finished at: Mon Dec 22 19:39:42 EST 2008
[INFO] Final Memory: 34M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/657/changes
