See http://hudson.opengeo.org/hudson/job/geoserver-trunk/678/changes
Changes:
[tschaub] Update rule panel example.
[tschaub] Removing rule builder example and updating legend example.
[...truncated 205 lines...]
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/2.0-SNAPSHOT/build-configs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/2.0-SNAPSHOT/build-configs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/2.0-SNAPSHOT/build-configs-2.0-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Jan 9, 2009 4:37:13 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/2.0-SNAPSHOT/platform-2.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 19 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 7 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.62 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jan 9, 2009 4:37:24 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.111 sec <<< FAILURE!
Results :
Tests in error:
testIntersectsWithFunction(org.geoserver.feature.ReprojectingFilterVisitorTest)
Tests run: 21, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports for the individual test results.
[INFO] Total time: 45 seconds
[INFO] Finished at: Fri Jan 09 16:37:25 EST 2009
[INFO] Final Memory: 25M/47M
Failed to send e-mail to tschaub because no e-mail address is known, and no default e-mail domain is configured
