See http://hudson.opengeo.org/hudson/job/geoserver-trunk/692/changes
Changes:
[bencaradocdavies] Add target to svn:ignore.
[jdeolive] GEOS-2433, adding db2 as an extension
started
Updating https://svn.codehaus.org/geoserver/trunk/src
U release/pom.xml
U release/ext-db2.xml
U community/app-schema
A extension/db2
AU extension/db2/pom.xml
U extension/pom.xml
Fetching 'http://svn.opengeo.org/geoext/apps/styler2/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app’
Fetching 'http://svn.opengeo.org/geoext/core/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/core’
At revision 1236
Fetching 'http://svn.opengeo.org/geoext/ext/2.2’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/ext’
At revision 1236
Fetching 'http://svn.openlayers.org/sandbox/topp/styler2’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/openlayers’
At revision 8650
Fetching 'http://svn.opengeo.org/who/ems/trunk/lib’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/tree’
At revision 113
Fetching 'http://svn.opengeo.org/geoext/ux’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/community/styler/app/externals/ux’
At revision 1236
At revision 1236
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal’
At revision 11025
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/minimal’
At revision 11025
At revision 11025
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/core/trunk at geoserver/externals/core
org.tmatesoft.svn.core.SVNException: svn: 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals’ is not a working copy
svn: Cannot read from to 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals/.svn/format’ : path refers to directory or read access is denied
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
at org.tmatesoft.svn.core.internal.wc.admin.SVNAdminAreaFactory.open(SVNAdminAreaFactory.java:132)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:344)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:261)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.probeOpen(SVNWCAccess.java:279)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1881)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1818)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:2172)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:631)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:601)
at hudson.FilePath.act(FilePath.java:301)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:308)
at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
at hudson.model.Run.run(Run.java:659)
at hudson.model.Build.run(Build.java:101)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:65)
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/ext/2.2 at geoserver/externals/ext
ERROR: Failed to parse svn info for external http://svn.openlayers.org/sandbox/topp/styler2 at geoserver/externals/openlayers
ERROR: Failed to parse svn info for external http://svn.opengeo.org/who/ems/trunk/lib at geoserver/externals/tree
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/ux at geoserver/externals/ux
no change for http://svn.opengeo.org/geoext/apps/styler2/trunk since the previous build
no revision recorded for null in the previous build
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
[geoserver] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver.extension:db2
POM Location: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/pom.xml
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geotools:gt-jdbc-db2
Reason: Failed to validate POM for project org.geoserver.extension:db2 at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/pom.xml
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver.extension:db2 at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/pom.xml
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:378)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:292)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver.extension:db2 at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/pom.xml
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1108)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:878)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:506)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:198)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:583)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:461)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:534)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
... 11 more
[INFO] Total time: 2 seconds
[INFO] Finished at: Wed Jan 14 01:36:32 EST 2009
[INFO] Final Memory: 5M/9M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
