[Geoserver-devel] Build failed in Hudson: geoserver-trunk #695
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/695/changes
Changes:
[bencaradocdavies] Added copyright statements.
[...truncated 4126 lines...]
      <guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></guid>
      <description><![CDATA[<h4>BasicPolygons</h4>
<ul class="textattributes">
  <li><strong><span class="atr-name">ID</span>:</strong> <span class="atr-value"></span></li>
</ul>
]]></description>
      <georss:polygon>5.0 -1.0 5.0 2.0 2.0 2.0 2.0 -1.0 5.0 -1.0</georss:polygon>
    </item>
  </channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Running org.vfny.geoserver.wms.responses.GetCapabilitiesTest
Jan 14, 2009 7:39:23 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.59 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.389 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Jan 14, 2009 7:39:25 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
DecribeFT URL for topp:states: http://demo.opengeo.org/geoserver/wfs?VERSION=1.1.0&TYPENAME=topp%3Astates&NAMESPACE=xmlns(topp%3Dhttp%3A%2F%2Fwww.openplans.org%2Ftopp)&REQUEST=DescribeFeatureType&SERVICE=WFS&=&
org.vfny.geoserver.wms.WmsException: Could not connect to remote OWS
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1105)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1024)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:182)
  at org.geoserver.wms.kvp.GetMapKvpRequestReaderTest.testRemoteWFSInvalidURL(GetMapKvpRequestReaderTest.java:324)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:129)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor120.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.net.UnknownHostException: phantom.openplans.org
  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
  at java.net.Socket.connect(Socket.java:520)
  at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
  at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
  at sun.net.www.http.HttpClient.New(HttpClient.java:304)
  at sun.net.www.http.HttpClient.New(HttpClient.java:321)
  at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:813)
  at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:765)
  at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:690)
  at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:934)
  at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:65)
  at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:675)
  at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:348)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1103)
  ... 33 more
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.716 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.343 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.255 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.213 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
14 Jan 07:39:26 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
  at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:104)
  at org.geoserver.ows.adapters.KvpRequestReaderAdapter.createRequest(KvpRequestReaderAdapter.java:94)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1056)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:430)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:984)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:951)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:447)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:428)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:46)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
14 Jan 07:39:28 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:609)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:702)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:660)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:173)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:133)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:169)
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.531 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.237 sec
Results :
Failed tests:
  testVectorWithRemoteLayer(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
Tests run: 139, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 59 seconds
[INFO] Finished at: Wed Jan 14 07:39:30 EST 2009
[INFO] Final Memory: 35M/63M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/696/changes
