[Geoserver-devel] Build failed in Hudson: geoserver-trunk #738
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/738/changes
Changes:
[jdeolive] syncing up id with name on save()
[...truncated 717 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:420)
  at org.geotools.referencing.CRS.decode(CRS.java:348)
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:987)
  ... 31 more
04 Feb 11:37:20 ERROR [geoserver.global] - Could not load feature type cite:BasicPolygons
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:991)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:516)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1599)
  at org.vfny.geoserver.global.Config.getData(Config.java:107)
  at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:47)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:133)
  ... 31 more
04 Feb 11:37:20 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Feb 04 11:37:20 EST 2009]; root of context hierarchy
04 Feb 11:37:20 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
04 Feb 11:37:20 INFO [geoserver.global] - Done disposing datastores.
Feb 4, 2009 11:37:20 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.13 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
04 Feb 11:37:20 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
04 Feb 11:37:20 INFO [geoserver.catalog] - Default namespace: 'gs'
04 Feb 11:37:20 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.config.util.XStreamPersisterTest
04 Feb 11:37:20 INFO [org.geoserver] - Persisting store 'bar'
04 Feb 11:37:20 INFO [org.geoserver] - Loaded store 'bar', disabled
04 Feb 11:37:20 INFO [org.geoserver] - Persisting workspace '{foo=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com, null=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com}'
04 Feb 11:37:20 INFO [org.geoserver] - Persisting namespace '{null=acme, acme=acme}'
04 Feb 11:37:20 INFO [org.geoserver] - Persisting store 'foo'
04 Feb 11:37:20 INFO [org.geoserver] - Loading workspace 'foo'
04 Feb 11:37:20 INFO [org.geoserver] - Loading namespace 'acme'
04 Feb 11:37:20 INFO [org.geoserver] - Loaded store 'foo', disabled
04 Feb 11:37:20 INFO [org.geoserver] - Persisting resource 'ft'
Feb 4, 2009 11:37:20 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
04 Feb 11:37:20 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Feb 4, 2009 11:37:20 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Feb 4, 2009 11:37:20 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Feb 4, 2009 11:37:21 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cgf'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 40, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec <<< FAILURE!
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Feb 4, 2009 11:37:21 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.088 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Results :
Failed tests:
  testModifyWorkspace(org.geoserver.catalog.impl.CatalogImplTest)
Tests run: 110, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 51 seconds
[INFO] Finished at: Wed Feb 04 11:37:21 EST 2009
[INFO] Final Memory: 29M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/739/changes
