[Geoserver-devel] Build failed in Hudson: geoserver-trunk #75
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/75/changes
Changes:
[jdeolive] change in geotools emf model artifact ids
[...truncated 354 lines...]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 68 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.556 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
  <ows:Exception exceptionCode="helloCode" locator="helloLocator">
    <ows:ExceptionText>hello service exception
helloText
I/O exception here
Illegal argument here</ows:ExceptionText>
    <ows:ExceptionText>helloText</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.24 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 119 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.384 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.433 sec
Running org.geoserver.feature.PagingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.436 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:arcgrid:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:geotiff:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gtopo30:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:image:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:imagemosaic:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] Compiling 35 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot; does not exist. Creating the directory.
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot; does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot; does not exist. Will create one.
Annotated grammar generated successfully in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.5-SNAPSHOT: checking for updates from maven-restlet
Downloading: http://lists.refractions.net/m2//org/geotools/ogc/net.opengis.wcs/2.5-SNAPSHOT/net.opengis.wcs-2.5-SNAPSHOT.pom
Downloading: http://maven.restlet.org/org/geotools/ogc/net.opengis.wcs/2.5-SNAPSHOT/net.opengis.wcs-2.5-SNAPSHOT.pom
Downloading: http://lists.refractions.net/m2//org/geotools/ogc/net.opengis.wcs/2.5-SNAPSHOT/net.opengis.wcs-2.5-SNAPSHOT.jar
Downloading: http://maven.restlet.org/org/geotools/ogc/net.opengis.wcs/2.5-SNAPSHOT/net.opengis.wcs-2.5-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools.ogc:net.opengis.wcs:jar:2.5-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools.ogc -DartifactId=net.opengis.wcs -Dversion=2.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geotools.ogc -DartifactId=net.opengis.wcs -Dversion=2.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:wcs1_1:jar:1.7.0-SNAPSHOT
    2) org.geotools.ogc:net.opengis.wcs:jar:2.5-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  maven-restlet (http://maven.restlet.org),
  refractions (http://lists.refractions.net/m2/),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
[INFO] Total time: 1 minute 1 second
[INFO] Finished at: Thu Apr 10 19:37:37 EDT 2008
[INFO] Final Memory: 30M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/76/changes
