See http://hudson.opengeo.org/hudson/job/geoserver-trunk/754/changes
Changes:
[bencaradocdavies] GEOS-2597: Change wms module to use DataAccess API (GSIP 31)
[bencaradocdavies] GEOS-2596: Change wfs module to use DataAccess API (GSIP 31)
[bencaradocdavies] GEOS-2595: Change web module to use DataAccess API (GSIP 31)
[bencaradocdavies] GEOS-2594: Change data module to use DataAccess API (GSIP 31)
[bencaradocdavies] GEOS-2569: Change main module to use DataAccess API (GSIP 31). Also added ResourcePoolTest.
[...truncated 3656 lines...]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-postgis:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-directory:2.6-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.273 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.47 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
[echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
[copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1704 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/2.0-SNAPSHOT/community-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from refractions
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.904 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.0-SNAPSHOT/h2-2.0-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.6-SNAPSHOT: checking for updates from refractions
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.0-SNAPSHOT/oracle-2.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.6-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/GetLog.java :[120,94] incompatible types
found : org.geotools.data.FeatureSource<capture of ? extends org.opengis.feature.type.FeatureType,capture of ? extends org.opengis.feature.Feature>
required: org.geotools.data.FeatureSource<org.opengis.feature.simple.SimpleFeatureType,org.opengis.feature.simple.SimpleFeature>
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/GetDiff.java :[117,94] incompatible types
[INFO] Total time: 3 minutes 51 seconds
[INFO] Finished at: Thu Feb 12 11:40:49 EST 2009
[INFO] Final Memory: 42M/63M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
