See http://hudson.opengeo.org/hudson/job/geoserver-trunk/764/changes
Changes:
[aaime] GEOS-2477 Invalid namespace URI cause an java.net.URISyntaxException from uDig
[...truncated 5375 lines...]
]]></description>
<georss:polygon>6.0 -2.0 6.0 1.0 3.0 1.0 3.0 -2.0 6.0 -2.0</georss:polygon>
</item>
<item>
<title>BasicPolygons.1107531493644</title>
<link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></link>
<guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></guid>
<description><![CDATA[<h4>BasicPolygons</h4>
<ul class="textattributes">
<li><strong><span class="atr-name">ID</span>:</strong> <span class="atr-value"></span></li>
</ul>
]]></description>
<georss:polygon>5.0 -1.0 5.0 2.0 2.0 2.0 2.0 -1.0 5.0 -1.0</georss:polygon>
</item>
</channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.312 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.186 sec
Running org.vfny.geoserver.wms.responses.GetCapabilitiesTest
Feb 16, 2009 5:42:37 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.29 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.068 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.77 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.252 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Feb 16, 2009 5:42:38 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.165 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.257 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.293 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.175 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
16 Feb 05:42:40 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:104)
at org.geoserver.ows.adapters.KvpRequestReaderAdapter.createRequest(KvpRequestReaderAdapter.java:94)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1075)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:430)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1039)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1006)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:453)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:434)
at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:80)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:133)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor136.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.797 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
16 Feb 05:42:41 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:623)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:702)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:708)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:173)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:133)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:169)
... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.999 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.181 sec
Results :
Tests run: 142, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.geotools:gt-graph:jar:2.6-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools),
opengeo (http://repo.opengeo.org/),
refractions (http://lists.refractions.net/m2/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
Path to dependency:
1) org.geoserver:gwc:jar:2.0-SNAPSHOT
2) org.geoserver:main:jar:2.0-SNAPSHOT
3) org.geotools:gt-validation:jar:2.6-SNAPSHOT
4) org.geotools:gt-graph:jar:2.6-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/geotools/gt-graph/2.6-SNAPSHOT/gt-graph-2.6-SNAPSHOT.jar
[INFO] Total time: 6 minutes 22 seconds
[INFO] Finished at: Mon Feb 16 05:43:09 EST 2009
[INFO] Final Memory: 36M/63M
