See http://hudson.opengeo.org/hudson/job/geoserver-trunk/786/changes
Changes:
[jdeolive] GEOS-2619, reviving support for schema.xml
[jdeolive] added toString() to return name
[jdeolive] upgraded xstream to 1.3.1
[jdeolive] changed osgeo repository to opengeo repository
[...truncated 4062 lines...]
</gml:Point>
</cdf:pointProperty>
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<gml:boundedBy>
<gml:Envelope>
<gml:lowerCorner>500000.0 500000.0</gml:lowerCorner>
<gml:upperCorner>500100.0 500100.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:pointProperty>
</gml:Point>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:pointProperty>
</gml:Point>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:pointProperty>
</gml:Point>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<gml:boundedBy>
<gml:Envelope>
</gml:Envelope>
</gml:boundedBy>
<cdf:pointProperty>
</gml:Point>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.175 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.wfs.DescribeFeatureTest
27 Feb 12:38:31 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:134)
at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:96)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy10.describeFeatureType(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:573)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1039)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1006)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:638)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:585)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:565)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:774)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:757)
at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:45)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:133)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor170.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.224 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.117 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.238 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.633 sec
Running org.geoserver.wfs.response.ShapeZipTest
Feb 27, 2009 12:38:33 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.581 sec
Running org.geoserver.wfs.GetCapabilitiesTest
27 Feb 12:38:33 ERROR [geoserver.wfs] - ERROR IN class org.geoserver.wfs.response.CSVOutputFormat IMPLEMENTATION. getCapabilitiesElementName() should return avalid XML element name string for use in the WFS 1.0.0 capabilities document.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Results :
Failed tests:
testGet(org.geoserver.wfs.response.GeoJSONTest)
testPost(org.geoserver.wfs.response.GeoJSONTest)
testCallbackFunction(org.geoserver.wfs.response.GeoJSONTest)
testInsertWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
Tests run: 152, Failures: 4, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 47 seconds
[INFO] Finished at: Fri Feb 27 12:38:34 EST 2009
[INFO] Final Memory: 37M/63M
