See http://hudson.opengeo.org/hudson/job/geoserver-trunk/790/changes
Changes:
[jdeolive] removed web, moved to legacy
[jdeolive] GEOS-2653, changed ServiceInfo to have reference to GeoServer, rather than GeoServerInfo
[jdeolive] GEOS-2650, moved config + dto + web code to legacy module
[...truncated 1349 lines...]
symbol : class GeoServer
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/ServiceException.java :[250,8] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/ServiceException.java :[308,30] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/servlets/ServiceStrategyFactory.java :[13,33] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/servlets/ServiceStrategyFactory.java :[30,4] cannot find symbol
location: class org.vfny.geoserver.servlets.ServiceStrategyFactory
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/servlets/ServiceStrategyFactory.java :[47,34] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/Requests.java :[11,33] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/Requests.java :[80,75] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/Requests.java :[116,78] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/Requests.java :[161,73] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/Requests.java :[240,81] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[12,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[13,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[14,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[15,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[16,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[17,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[18,33] package org.vfny.geoserver.config does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[79,12] cannot find symbol
symbol : class CoverageStoreConfig
location: class org.vfny.geoserver.global.UserContainer
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[84,12] cannot find symbol
symbol : class DataStoreConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[108,12] cannot find symbol
symbol : class NameSpaceConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[111,12] cannot find symbol
symbol : class StyleConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[120,12] cannot find symbol
symbol : class FeatureTypeConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[125,12] cannot find symbol
symbol : class CoverageConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[152,12] cannot find symbol
symbol : class AttributeTypeInfoConfig
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[172,12] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[265,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[274,39] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[301,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[310,35] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[337,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[346,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[355,32] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[400,37] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[409,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[418,35] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[445,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[454,25] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[478,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[486,36] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[510,11] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/UserContainer.java :[518,34] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/config/util/LegacyConfigurationImporter.java :[27,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/GeoserverDataDirectory.java :[52,19] cannot find symbol
symbol : class Data
location: class org.vfny.geoserver.global.GeoserverDataDirectory
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/GeoserverDataDirectory.java :[385,19] cannot find symbol
symbol : class Data
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/config/util/ServiceLoader.java :[15,33] cannot find symbol
symbol : class MetaDataLink
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/template/GeoServerTemplateLoader.java :[16,33] cannot find symbol
symbol : class CoverageInfo
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/ows/adapters/ResponseAdapter.java :[12,33] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/ows/adapters/ResponseAdapter.java :[30,4] cannot find symbol
location: class org.geoserver.ows.adapters.ResponseAdapter
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/ows/adapters/ResponseAdapter.java :[32,48] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/requests/CapabilitiesRequest.java :[8,33] cannot find symbol
symbol : class Service
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/requests/CapabilitiesRequest.java :[31,51] cannot find symbol
location: class org.vfny.geoserver.util.requests.CapabilitiesRequest
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/util/requests/CapabilitiesRequest.java :[42,51] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[65,33] cannot find symbol
symbol : class CoverageDimension
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[66,33] cannot find symbol
symbol : class FeatureTypeInfo
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[68,33] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[69,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[70,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[71,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[72,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[73,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[74,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[75,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[76,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[77,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[78,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[79,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[80,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[81,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[82,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[83,37] package org.vfny.geoserver.global.dto does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/global/xml/XMLConfigReader.java :[121,12] cannot find symbol
symbol : class WMSDTO
location: class org.vfny.geoserver.global.xml.XMLConfigReader
[INFO] Total time: 30 seconds
[INFO] Finished at: Sat Feb 28 14:37:31 EST 2009
[INFO] Final Memory: 34M/63M
