[Geoserver-devel] Build failed in Hudson: geoserver-trunk #8
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/8/changes
Changes:
[jdeolive] Added test case
[jdeolive] moved xml config from listener to controller
[jdeolive] encoding transaction
[jdeolive] handling delete event, storing actual tx object
[jdeolive] firing post insert event
[...truncated 2092 lines...]
  at sun.reflect.GeneratedMethodAccessor87.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:735)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:330)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:311)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:478)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:331)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:102)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.348 sec
Running org.geoserver.wfs.v1_1.TransactionTest
Mar 12, 2008 2:38:01 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
12 Mar 14:38:03 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: No such property: {http://www.opengis.net/wfs\}INVALID
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:110)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:229)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:157)
  at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor92.invoke(Unknown Source)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:436)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:528)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:534)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.644 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
12 Mar 14:38:03 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
12 Mar 14:38:03 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.068 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.872 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.516 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
12 Mar 14:38:09 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
12 Mar 14:38:09 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.844 sec
Running org.geoserver.wfs.ReprojectionTest
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns="http://www.opengis.net/wfs&quot; xmlns:cite="http://www.opengis.net/cite&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/cite http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.0.0&amp;request=DescribeFeatureType&amp;typeName=cite:GoogleFeatures http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#900913&quot;&gt;
<gml:coordinates cs="," decimal="." ts=" " xmlns:gml="http://www.opengis.net/gml&quot;&gt;0,\-0 1113194.90793274,1118889.97485796</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:GoogleFeatures fid="GoogleGeometries.1">
<cite:the_geom>
<gml:LineString srsName="http://www.opengis.net/gml/srs/epsg.xml#900913&quot;&gt;
</gml:LineString>
</cite:the_geom>
<cite:name>Google</cite:name>
</cite:GoogleFeatures>
</gml:featureMember>
</wfs:FeatureCollection>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.593 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.56 sec <<< FAILURE!
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.756 sec
Running org.geoserver.wfs.DescribeFeatureTest
12 Mar 14:38:12 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
  at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.392 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.26 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Results :
Failed tests:
  testInsert(org.geoserver.wfs.TransactionListenerTest)
Tests run: 128, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/trunk/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes
[INFO] Finished at: Wed Mar 12 14:38:18 EDT 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/9/changes
