See http://hudson.opengeo.org/hudson/job/geoserver-trunk/822/changes
Changes:
[aaime] First cut at GEOS-2697, refactored out a generic data provider that pages must specialize with their own custom data
[...truncated 97 lines...]
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1881)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:1818)
at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:2172)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:631)
at hudson.scm.SubversionSCM$BuildRevisionMapTask.invoke(SubversionSCM.java:601)
at hudson.FilePath.act(FilePath.java:301)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:308)
at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
at hudson.model.Run.run(Run.java:659)
at hudson.model.Build.run(Build.java:101)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:65)
ERROR: Failed to parse svn info for external http://svn.opengeo.org/geoext/ux at geoserver/externals/ux
org.tmatesoft.svn.core.SVNException: svn: 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals’ is not a working copy
svn: Cannot read from to 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/externals/.svn/format’ : path refers to directory or read access is denied
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
at org.tmatesoft.svn.core.internal.wc.admin.SVNAdminAreaFactory.open(SVNAdminAreaFactory.java:132)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:344)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:261)
at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.probeOpen(SVNWCAccess.java:279)
no change for http://svn.opengeo.org/geoext/apps/styler2/trunk since the previous build
no revision recorded for null in the previous build
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
[geoserver] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO] ArcSDE DataStore Extension
[INFO] H2 DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] Versioned Web Feature Service Module
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Building GeoServer
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt-api:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-referencing:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-metadata:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:geoapi:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:parent:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:geoapi-pending:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.0-SNAPSHOT/geoserver-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.0-SNAPSHOT/geoserver-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver:platform:jar:2.0-SNAPSHOT
2) org.geotools:gt-api:jar:2.6-SNAPSHOT
3) org.geotools:gt-referencing:jar:2.6-SNAPSHOT
4) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
5) org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi-pending/2.3-SNAPSHOT/geoapi-pending-2.3-SNAPSHOT.jar
[INFO] Total time: 15 seconds
[INFO] Finished at: Wed Mar 11 09:37:23 EDT 2009
[INFO] Final Memory: 22M/43M
