[Geoserver-devel] Build failed in Hudson: geoserver-trunk #839
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/839/changes
Changes:
[aaime] Forgot to rename the html class when renaming the UI class
[...truncated 4093 lines...]
Mar 17, 2009 10:41:09 AM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse since test data is not available
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Running org.geoserver.wfsv.LogOrderTest
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogForward since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogBackwards since test data is not available
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
17 Mar 10:41:09 WARN [data.tes] - Disabling test based on fixture wfsv since the file /home/tomcat/.geoserver/wfsv.properties could not be found
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.066 sec
Running org.geoserver.wfsv.RollbackTest
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testInvalidRollback since test data is not available
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0-SNAPSHOT/wfsv-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0-SNAPSHOT/wfsv-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0-SNAPSHOT/wfsv-2.0-SNAPSHOT-sources.jar
[INFO] Building DB2 DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-jdbc-db2:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0-SNAPSHOT/db2-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0-SNAPSHOT/db2-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0-SNAPSHOT/db2-2.0-SNAPSHOT-sources.jar
[INFO] Building ImageMap Output Format
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 12 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest
Mar 17, 2009 10:41:21 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/test-classes/org/vfny/geoserver/wms/responses/map/htmlimagemap/test-data
Mar 17, 2009 10:41:22 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap writeLayers
INFO: Definition Query: Query.ALL
Mar 17, 2009 10:41:22 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter$HTMLImageMapFeatureWriter writeMultiFeature
WARNING: Problems encoding shape: Nothing to encode
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap encode
INFO: HTML ImageMap generated in 292 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceBasicPolygons
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap writeLayers
INFO: HTML ImageMap generated in 4 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePolygonsWithHoles
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[0.0 : 8.0, 0.0 : 8.0]
INFO: HTML ImageMap generated in 10 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePolygonsWithSkippedHoles
INFO: HTML ImageMap generated in 2 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceReproject
INFO: about to create map ctx for ProjectedPolygon with bounds ReferencedEnvelope[2315725.0 : 2315754.0, 4833303.0 : 4833338.0]
INFO: HTML ImageMap generated in 37 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceLines
INFO: about to create map ctx for RoadSegments with bounds ReferencedEnvelope[-0.0042 : 0.0042, -0.0024 : 0.0024]
INFO: HTML ImageMap generated in 58 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapRuleWithFilters
INFO: about to create map ctx for RoadSegments with filter on name and bounds ReferencedEnvelope[-0.0042 : 0.0042, -0.0024 : 0.0024]
INFO: HTML ImageMap generated in 6 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePoints
INFO: about to create map ctx for BuildingCenters with bounds ReferencedEnvelope[0.0010 : 0.0022, 6.0E-4 : 9.0E-4]
INFO: HTML ImageMap generated in 23 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceMultiPoints
INFO: about to create map ctx for BuildingCentersMultiPoint with bounds ReferencedEnvelope[0.0010 : 0.0022, 6.0E-4 : 9.0E-4]
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceCollection
INFO: about to create map ctx for RoadSegments with bounds ReferencedEnvelope[-0.0042 : 0.0022, -6.0E-4 : 9.0E-4]
INFO: HTML ImageMap generated in 5 ms
Mar 17, 2009 10:41:23 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceNoCoords
INFO: about to create map ctx for NamedPlaces with bounds ReferencedEnvelope[2.0 : 6.0, 2.0 : 6.0]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.426 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/imagemap/2.0-SNAPSHOT/imagemap-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/imagemap/2.0-SNAPSHOT/imagemap-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/imagemap-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/imagemap/2.0-SNAPSHOT/imagemap-2.0-SNAPSHOT-sources.jar
[INFO] Building ogr2ogr Output Format
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/ogr/target
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/),
  maven2-repository.dev.java.net (http://download.java.net/maven/2),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver.extension:ogr:jar:2.0-SNAPSHOT
  2) org.geoserver:wfs:jar:2.0-SNAPSHOT
  3) org.geoserver:main:jar:2.0-SNAPSHOT
  4) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
  5) org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi-pending/2.3-SNAPSHOT/geoapi-pending-2.3-SNAPSHOT.jar
[INFO] Total time: 3 minutes 48 seconds
[INFO] Finished at: Tue Mar 17 10:41:25 EDT 2009
[INFO] Final Memory: 40M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/840/changes
