See http://hudson.opengeo.org/hudson/job/geoserver-trunk/851/changes
Changes:
[jdeolive] updated global settings page to reflect chagnes in logging config
[jdeolive] reverting accidental commit
[jdeolive] GeoServerInfo changed to take GeoServer in constructor
[jdeolive] disabled save and revert buttons
[jdeolive] moved logging and jaito first class config objects
[jdeolive] setting legacy persistance for tests
[jdeolive] aliasing WCSInfo for persistance
[jdeolive] registering xstream based loader
[jdeolive] Changed config listener to extend adapter
[jdeolive] GEOS-2663, JAIInfo made first class config object
[jdeolive] aliasing WMSInfo object for persistence
[jdeolive] GeoServerInfo changed to take reference to GeoServer
[jdeolive] added legacy loader
[jdeolive] aliasing WFSInfo for persistance
[jdeolive] changed legacy catalog reader to return map of datastores instead of a list
[jdeolive] implemented toString() to return workspace name
[jdeolive] added hook for configuring xstream persister
[jdeolive] added persistance of service config objects, removed some redundant logging, tweaked grid envelope unmarshalling
[jdeolive] added logging and jai config create methods
[jdeolive] added logging config events, and a post service change event
[jdeolive] added JAIInfo as first level config object, seperated logging into seperate logging object
[jdeolive] GEOS-2663, made JAIInfo first class configuration object
[jdeolive] GEOS-2727, made logging configuration seperate object
[jdeolive] created a configuration listener adapter for event listeners
[jdeolive] GEOS-2674, added 2.x style loading and persistance of data directory
[jdeolive] GEOS-2674, added GeoServer persister for persisting changes in response to events
[...truncated 1848 lines...]
166/166K
166K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-data/2.6-SNAPSHOT/gt-data-2.6-20090319.063128-21.jar
4/26K
8/26K
10/26K
14/26K
18/26K
22/26K
26/26K
26/26K
26K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.6-SNAPSHOT/gt-jdbc-2.6-20090319.063128-20.jar
3/138K
7/138K
11/138K
15/138K
19/138K
20/138K
24/138K
28/138K
32/138K
36/138K
40/138K
44/138K
48/138K
52/138K
53/138K
57/138K
61/138K
65/138K
69/138K
73/138K
77/138K
81/138K
85/138K
89/138K
93/138K
97/138K
101/138K
105/138K
109/138K
113/138K
117/138K
121/138K
125/138K
129/138K
133/138K
137/138K
138/138K
138K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.6-SNAPSHOT/gt-property-2.6-20090319.063128-20.jar
4/19K
8/19K
12/19K
16/19K
19/19K
19K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-epsg-hsql/2.6-SNAPSHOT/gt-epsg-hsql-2.6-20090319.063128-20.jar
4/653K
8/653K
12/653K
16/653K
20/653K
24/653K
28/653K
32/653K
36/653K
40/653K
44/653K
48/653K
52/653K
56/653K
60/653K
64/653K
68/653K
72/653K
76/653K
80/653K
84/653K
88/653K
92/653K
96/653K
100/653K
104/653K
108/653K
112/653K
116/653K
120/653K
124/653K
128/653K
132/653K
136/653K
140/653K
144/653K
148/653K
152/653K
156/653K
160/653K
164/653K
168/653K
172/653K
176/653K
180/653K
184/653K
188/653K
192/653K
196/653K
200/653K
204/653K
208/653K
212/653K
216/653K
220/653K
224/653K
228/653K
232/653K
236/653K
240/653K
244/653K
248/653K
252/653K
256/653K
260/653K
264/653K
268/653K
272/653K
276/653K
280/653K
284/653K
288/653K
292/653K
296/653K
300/653K
304/653K
308/653K
312/653K
316/653K
320/653K
324/653K
328/653K
332/653K
336/653K
340/653K
344/653K
348/653K
352/653K
356/653K
360/653K
364/653K
368/653K
372/653K
376/653K
380/653K
384/653K
388/653K
392/653K
396/653K
400/653K
404/653K
408/653K
412/653K
416/653K
420/653K
424/653K
428/653K
432/653K
436/653K
440/653K
444/653K
448/653K
452/653K
456/653K
460/653K
464/653K
468/653K
472/653K
476/653K
480/653K
484/653K
488/653K
492/653K
496/653K
500/653K
504/653K
508/653K
512/653K
516/653K
520/653K
524/653K
528/653K
532/653K
536/653K
540/653K
544/653K
548/653K
552/653K
556/653K
560/653K
564/653K
568/653K
572/653K
576/653K
580/653K
584/653K
588/653K
592/653K
596/653K
596/653K
600/653K
604/653K
606/653K
608/653K
612/653K
613/653K
616/653K
618/653K
622/653K
625/653K
629/653K
633/653K
637/653K
639/653K
643/653K
647/653K
651/653K
653/653K
653K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 216 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/util/LegacyCatalogReader.java :[12,25] package com.sun.tools.jdi does not exist
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/catalog/util/LegacyCatalogReader.java :[101,29] cannot find symbol
symbol : class LinkedHashMap
location: class org.geoserver.catalog.util.LegacyCatalogReader
[INFO] Total time: 52 seconds
[INFO] Finished at: Thu Mar 19 02:38:31 EDT 2009
[INFO] Final Memory: 30M/63M
