See http://hudson.opengeo.org/hudson/job/geoserver-trunk/862/changes
Changes:
[aaime] Adding simpler CoverageInfo/FeatureTypeInfo construction methods to catalog
[...truncated 805 lines...]
712/1159K
716/1159K
720/1159K
724/1159K
728/1159K
732/1159K
736/1159K
740/1159K
744/1159K
748/1159K
752/1159K
756/1159K
760/1159K
764/1159K
768/1159K
772/1159K
776/1159K
780/1159K
784/1159K
788/1159K
792/1159K
796/1159K
800/1159K
804/1159K
808/1159K
812/1159K
816/1159K
820/1159K
824/1159K
828/1159K
832/1159K
836/1159K
840/1159K
844/1159K
848/1159K
852/1159K
856/1159K
860/1159K
864/1159K
868/1159K
872/1159K
876/1159K
880/1159K
884/1159K
888/1159K
892/1159K
896/1159K
900/1159K
904/1159K
908/1159K
912/1159K
916/1159K
920/1159K
924/1159K
928/1159K
932/1159K
936/1159K
940/1159K
944/1159K
948/1159K
952/1159K
956/1159K
960/1159K
964/1159K
968/1159K
972/1159K
976/1159K
980/1159K
984/1159K
988/1159K
992/1159K
996/1159K
1000/1159K
1004/1159K
1008/1159K
1012/1159K
1016/1159K
1020/1159K
1024/1159K
1028/1159K
1032/1159K
1036/1159K
1040/1159K
1044/1159K
1048/1159K
1052/1159K
1056/1159K
1060/1159K
1064/1159K
1068/1159K
1072/1159K
1076/1159K
1080/1159K
1084/1159K
1088/1159K
1092/1159K
1096/1159K
1100/1159K
1104/1159K
1108/1159K
1112/1159K
1116/1159K
1120/1159K
1124/1159K
1128/1159K
1132/1159K
1136/1159K
1140/1159K
1144/1159K
1148/1159K
1152/1159K
1156/1159K
1159/1159K
1159K downloaded
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.0-SNAPSHOT/geoserver-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.0-SNAPSHOT/geoserver-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/2.0-SNAPSHOT/maven-2.0-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.0-SNAPSHOT/config-2.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.0-SNAPSHOT/archetype-2.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.opengis:geoapi:jar:2.3-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver.maven:geoserver-archetype-wfsoutputformat:jar:2.0-SNAPSHOT
2) org.geotools:gt-api:jar:2.6-SNAPSHOT
3) org.geotools:gt-referencing:jar:2.6-SNAPSHOT
4) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
5) org.opengis:geoapi:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi/2.3-SNAPSHOT/geoapi-2.3-SNAPSHOT.jar
[INFO] Total time: 26 seconds
[INFO] Finished at: Fri Mar 20 10:37:55 EDT 2009
[INFO] Final Memory: 23M/42M
