[Geoserver-devel] Build failed in Hudson: geoserver-trunk #874
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/874/changes
Changes:
[jdeolive] added writeStyle() and readStyle()
[jdeolive] added method for looking up and resolving style file
[...truncated 3629 lines...]
<ul class="textattributes">
</ul>
]]></description>
      <georss:polygon>5.0 -1.0 5.0 2.0 2.0 2.0 2.0 -1.0 5.0 -1.0</georss:polygon>
    </item>
  </channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.299 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.072 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Running org.vfny.geoserver.wms.responses.GetCapabilitiesTest
Mar 24, 2009 4:40:27 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.562 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.051 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.586 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.275 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Mar 24, 2009 4:40:29 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
DecribeFT URL for topp:states: http://demo.opengeo.org/geoserver/wfs?VERSION=1.1.0&TYPENAME=topp%3Astates&NAMESPACE=xmlns(topp%3Dhttp%3A%2F%2Fwww.openplans.org%2Ftopp)&REQUEST=DescribeFeatureType&SERVICE=WFS&=&
org.vfny.geoserver.wms.WmsException: Could not connect to remote OWS
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1123)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1029)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:178)
  at org.geoserver.wms.kvp.GetMapKvpRequestReaderTest.testRemoteWFSInvalidURL(GetMapKvpRequestReaderTest.java:328)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor119.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.net.UnknownHostException: phantom.openplans.org
  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
  at java.net.Socket.connect(Socket.java:520)
  at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
  at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
  at sun.net.www.http.HttpClient.New(HttpClient.java:304)
  at sun.net.www.http.HttpClient.New(HttpClient.java:321)
  at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:813)
  at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:765)
  at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:690)
  at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:934)
  at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:65)
  at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:684)
  at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:347)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1121)
  ... 33 more
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.784 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.186 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
24 Mar 16:40:31 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
  at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:109)
  at org.geoserver.wms.kvp.WMSKvpRequestReaderAdapter.createRequest(WMSKvpRequestReaderAdapter.java:72)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1088)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:430)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:435)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:79)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.588 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
24 Mar 16:40:32 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:625)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:702)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:709)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.26 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.21 sec
Results :
Failed tests:
  testExternalGraphicBackround(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
Tests in error:
  testMissingGraphic(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
Tests run: 144, Failures: 1, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 53 seconds
[INFO] Finished at: Tue Mar 24 16:40:34 EDT 2009
[INFO] Final Memory: 38M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/875/changes
Changes:
[aaime] First stab at editing envelopes and CRS
[aaime] Import cleanup, add suppress warning for serialization, added a shared logger
[aaime] Deal with ReferencedEnvelope, get rid of the unecessary form, make it play as a standard form component (no need for explicit method call to updateModel)
[aaime] Show WKT in a <pre> section and set the popup title to the same string used in the srs link
[...truncated 1441 lines...]
24 Mar 18:39:14 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:671)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:177)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:126)
  ... 50 more
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:639)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:586)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:566)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:775)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:758)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:189)
  ... 49 more
  ... 51 more
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:196)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:173)
  ... 50 more
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.507 sec
Results :
Tests run: 77, Failures: 0, Errors: 0, Skipped: 0
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.opengis:geoapi:jar:2.3-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/),
  maven2-repository.dev.java.net (http://download.java.net/maven/2),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver:wcs1_1:jar:2.0-SNAPSHOT
  2) org.geoserver:main:jar:2.0-SNAPSHOT
  3) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
  4) org.opengis:geoapi:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi/2.3-SNAPSHOT/geoapi-2.3-SNAPSHOT.jar
[INFO] Total time: 1 minute 38 seconds
[INFO] Finished at: Tue Mar 24 18:39:15 EDT 2009
[INFO] Final Memory: 34M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/876/changes
Changes:
[jdeolive] GEOS-2151, style pages
[jdeolive] made feedback panel visisble to subclasses
[jdeolive] added some checks to validate() methods to ensure duplicate resources/stores/etc... are not added to catalog
[...truncated 407 lines...]
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.665 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.281 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/2.0-SNAPSHOT/ows-2.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:compile]
[INFO] Compiling 216 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:ows:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] [compiler:testCompile]
[INFO] Compiling 39 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.572 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 24, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 6.401 sec <<< FAILURE!
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.281 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
24 Mar 20:38:32 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Mar 24 20:38:32 EDT 2009]; root of context hierarchy
24 Mar 20:38:32 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
24 Mar 20:38:32 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Mar 20:38:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock58848data
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
24 Mar 20:38:32 INFO [geoserver.catalog] - Default namespace: 'gs'
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded style 'Default'
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded style 'Buildings'
24 Mar 20:38:32 INFO [geoserver.catalog] - Processed data store 'cite', enabled
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
24 Mar 20:38:32 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
24 Mar 20:38:32 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Mar 24 20:38:32 EDT 2009]; root of context hierarchy
24 Mar 20:38:32 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Running org.geoserver.config.LegacyConfigurationImporterTest
Mar 24, 2009 8:38:32 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.config.util.XStreamPersisterTest
24 Mar 20:38:32 INFO [org.geoserver] - Loaded store 'bar', disabled
24 Mar 20:38:32 INFO [org.geoserver] - Loading workspace 'foo'
24 Mar 20:38:32 INFO [org.geoserver] - Loading namespace 'acme'
24 Mar 20:38:32 INFO [org.geoserver] - Loaded store 'foo', disabled
Mar 24, 2009 8:38:32 PM java.util.prefs.FileSystemPreferences$7 run
24 Mar 20:38:32 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.158 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.169 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
24 Mar 20:38:32 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
24 Mar 20:38:32 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
24 Mar 20:38:32 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
24 Mar 20:38:32 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
24 Mar 20:38:32 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
24 Mar 20:38:32 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.096 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.348 sec
Running org.geoserver.security.SecureCatalogImplTest
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
24 Mar 20:38:33 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
24 Mar 20:38:33 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
24 Mar 20:38:33 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
24 Mar 20:38:33 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
24 Mar 20:38:33 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.067 sec
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.216 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.118 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
24 Mar 20:38:35 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
24 Mar 20:38:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
24 Mar 20:38:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
24 Mar 20:38:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
24 Mar 20:38:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.542 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 41, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.026 sec <<< FAILURE!
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Results :
Tests in error:
  testModifyDataStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverage(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyle(org.geoserver.config.GeoServerPersisterTest)
  testModifyFeatureType(org.geoserver.catalog.impl.CatalogImplTest)
  testNamespaceEvents(org.geoserver.catalog.impl.CatalogImplTest)
  testDataStoreEvents(org.geoserver.catalog.impl.CatalogImplTest)
  testFeatureTypeEvents(org.geoserver.catalog.impl.CatalogImplTest)
  testLayerEvents(org.geoserver.catalog.impl.CatalogImplTest)
  testStyleEvents(org.geoserver.catalog.impl.CatalogImplTest)
Tests run: 171, Failures: 0, Errors: 12, Skipped: 0
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 6 seconds
[INFO] Finished at: Tue Mar 24 20:38:35 EDT 2009
[INFO] Final Memory: 33M/62M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/877/changes
Changes:
[jdeolive] added checks for maintaining referential integrity to the catalog
[...truncated 386 lines...]
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.65 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.245 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.561 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 24, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 6.872 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.256 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.273 sec
24 Mar 21:38:23 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Mar 24 21:38:23 EDT 2009]; root of context hierarchy
24 Mar 21:38:23 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
24 Mar 21:38:23 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Mar 21:38:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock40697data
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
24 Mar 21:38:23 INFO [geoserver.catalog] - Default namespace: 'gs'
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded style 'Default'
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded style 'Buildings'
24 Mar 21:38:23 INFO [geoserver.catalog] - Processed data store 'cite', enabled
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
24 Mar 21:38:23 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
24 Mar 21:38:23 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Mar 24 21:38:23 EDT 2009]; root of context hierarchy
24 Mar 21:38:23 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Mar 24, 2009 9:38:23 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
24 Mar 21:38:24 INFO [org.geoserver] - Loaded store 'bar', disabled
24 Mar 21:38:24 INFO [org.geoserver] - Loading workspace 'foo'
24 Mar 21:38:24 INFO [org.geoserver] - Loading namespace 'acme'
24 Mar 21:38:24 INFO [org.geoserver] - Loaded store 'foo', disabled
Mar 24, 2009 9:38:24 PM java.util.prefs.FileSystemPreferences$7 run
24 Mar 21:38:24 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.118 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Mar 24, 2009 9:38:24 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.174 sec
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
24 Mar 21:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
24 Mar 21:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
24 Mar 21:38:24 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
24 Mar 21:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
24 Mar 21:38:24 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
24 Mar 21:38:24 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.241 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.201 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.103 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.413 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.227 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
24 Mar 21:38:27 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
24 Mar 21:38:27 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
24 Mar 21:38:27 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
24 Mar 21:38:27 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
24 Mar 21:38:27 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.496 sec
Tests run: 41, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.031 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Results :
Tests in error:
[INFO] Total time: 56 seconds
[INFO] Finished at: Tue Mar 24 21:38:27 EDT 2009
[INFO] Final Memory: 29M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/878/changes
Changes:
[jdeolive] fixing build for java 6
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.716 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.257 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.066 sec
Tests run: 24, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 6.624 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
25 Mar 00:38:17 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Mar 25 00:38:17 EDT 2009]; root of context hierarchy
25 Mar 00:38:17 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
25 Mar 00:38:17 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
25 Mar 00:38:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock32489data
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
25 Mar 00:38:17 INFO [geoserver.catalog] - Default namespace: 'gs'
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded style 'Default'
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded style 'Buildings'
25 Mar 00:38:17 INFO [geoserver.catalog] - Processed data store 'cite', enabled
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
25 Mar 00:38:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
25 Mar 00:38:17 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Mar 25 00:38:17 EDT 2009]; root of context hierarchy
25 Mar 00:38:17 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Mar 25, 2009 12:38:17 AM org.geoserver.platform.GeoServerExtensions checkContext
25 Mar 00:38:18 INFO [org.geoserver] - Loaded store 'bar', disabled
25 Mar 00:38:18 INFO [org.geoserver] - Loading workspace 'foo'
25 Mar 00:38:18 INFO [org.geoserver] - Loading namespace 'acme'
25 Mar 00:38:18 INFO [org.geoserver] - Loaded store 'foo', disabled
Mar 25, 2009 12:38:18 AM java.util.prefs.FileSystemPreferences$7 run
25 Mar 00:38:18 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.156 sec
Mar 25, 2009 12:38:18 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.189 sec
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.r=WRITER is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.w=WRITER is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.r=READER is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
25 Mar 00:38:18 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
25 Mar 00:38:18 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
25 Mar 00:38:18 WARN [geoserver.securit] - Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
25 Mar 00:38:18 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
25 Mar 00:38:18 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
25 Mar 00:38:18 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.185 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.219 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
25 Mar 00:38:20 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Mar 00:38:20 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
25 Mar 00:38:20 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
25 Mar 00:38:20 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
25 Mar 00:38:20 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.493 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Results :
Tests in error:
[INFO] Total time: 59 seconds
[INFO] Finished at: Wed Mar 25 00:38:21 EDT 2009
[INFO] Final Memory: 33M/61M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/879/changes
Changes:
[bencaradocdavies] GEOS-2780: CatalogImpl validation too aggressive, breaks the build
</ul>
]]></description>
    </item>
  </channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Mar 25, 2009 7:41:06 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.057 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.522 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.261 sec
Mar 25, 2009 7:41:07 AM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.165 sec
  ... 33 more
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.996 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.376 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.227 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
25 Mar 07:41:10 ERROR [geoserver.ows] -
</ServiceException>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.983 sec
25 Mar 07:41:11 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.794 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.153 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.222 sec
Results :
Failed tests:
Tests in error:
[INFO] Total time: 3 minutes 27 seconds
[INFO] Finished at: Wed Mar 25 07:41:12 EDT 2009
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/880/changes
